tips on storage (1 Viewer)
stevetracey
32
34
Plymouth
I'm a newbie November 2014
Thanks for all your advice so far. Taking the plunge for first overnight stay this weekend with the dogs in tow, they are not impressed with it at the mo!
Just started loading up a few essentials and wondering how you store certain things, like wine bottles, lemonade, mugs etc., any tips would be great, thanks, Tracey
DBK
18,019
48,071
Plympton, Devon
PVC, Murvi Morocco
You just need to stop things rattling. Paper towels, tea towels, purpose made stuff. Hard to generalise but you will know if you get it wrong!
10,187
57,410
Market Harborough
C Class Laika Ecovip 7R
Wine and large bottle I carry in a 6 bottle wine carrier you get from the supermarket. Mugs etc I wrap in bubble wrap then I throw a spar blanket in the locker to try and minimise any rattle. I'm sure others will be along to give you better advise. (y)
Puddleduck
12,385
43,987
Scottish Borders
Without at present
On and off for many years.
We made a bottle stand* that goes into the dead space behind the driver's seat and the bulkhead. All the bottles go in there.
I got a roll of the stuff that is sold to stop rugs slipping from IKEA and cut bits off it to put between plates etc. Works great and much cheaper than the same stuff (or very similar) sold as drawer / shelf liner. Tea towels, towels, oven gloves and apron get pushed in where there is space. Somehow it all works but I want to get cupboard dividers to make it easier to get stuff out as the anti-slip stuff works a bit too well at times.
*based on the wine carrier David mentioned above but dimensions altered to fit the space.
Badknee
7,407
412,566
notloB
Vantage Neo
Living the dream.
We invested in camping plates/bowls/ mugs etc. light and don't rattle. Heavy stuff low down over an axle if you can and pack everything tight, bedding/ pillows high up. If your anything like us you will be moving stuff around a lot :LOL:
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Wine bottles in socks. Some of that grey neoprene convoluted stuff from Aldi to stop cooker shelves rattling. Plate rack, the type where you stack them vertically so they lean on each other and, also, take up minimum space. Glasses in a purpose made wall rack. Mugs in individual plastic bags (zip seal work). Everything else in the kitchen in little plastic baskets, because the cupboards are higher than the ones in our kitchen at home and, consequently, are awkward for accessing stuff at the back, so we lift the baskets out.
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
In 8 years (low numbers compared to some I know) ooftowing a tin shed and now the camper I have always just put it away.. plate rack for the space saving, cups and glasses upside down on a sheet of the non slip stuff and bottles laid down in a low cupboard. Only ever had a single glass broken in transit and the only rattle is the cutlery draw (which I now pad with t-towels.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Think you'll find, now you've moved in with the 'orchestra', you'll notice a lot more noise than when tugging. Try some of that non-slip stuff in your cutlery drawer. It's the drawer itself that produces most noise. Lying the bottles down is a good idea, if you can stop them sliding about or rolling,
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
We use ikea plate racks and stack the crockery plates flat. We found a foam 'template' in Germany for different size glasses to stand in and we put these little latex sock things on the glasses as they stack to stop them rattling... We have a couple of muggi's for mugs. We use a large food container for the double skillet... (thanks Graham)
sedge
Jul 7, 2009
5,504
13,113
Nr Jct 3 M6
C class
Aug 09 to date 9,000 miles!
Have to say, in the Bessie the pan supports on the hob used to rattle, presumably against the glass 'lid'. So I used to lay a teatowel opened, over the hob and shut the glass lid down on that.
All the baking tins and one frying pan live inside the oven, with a knackered frayed and worn out old hand-towel is wrapped round them. The grill pan which does rattle about in its cavity, also gets wrapped in ditto.
Shelves covered in the non-slip stuff, Arcopal 'crockery' stacked, folded into 8 clean teatowels stacked on top of the teaplates standing on the diner plates. Mugs upside down on the non-slip.
Cutlery drawer doesn't rattle! - but then, it is full.
Larder - plastic baskets for condiments, any glass jars and odds and ends, tins in a single layer. Fresh veg in 'garage' under bed, in a faux linen shopping bag Jacksons gave us once at one of the shows.
A lot of the stuff in there eg shoes, is in 'stacka crates' - the sort that fold flat when they are empty. Spare bedlinen and towels are in two large lidded plastic boxes, which also stack. Sort of like giant Tupperware with a breathable seal LOL Dirt cheap one day from B &M, think they were about £3 each. Other places seemed to charge nearly a tenner for the same thing.
We each have an overhead locker and a drawer each. We each have plastic baskets - I keep underwear in one, socks and odds and ends in the other. Pete much the same and we can stack the baskets on the locker bottom shelf (none of that stuff needs to be flat anyway really) so we still each have 1.5 shelves for whatever. And some hanging space in the wardrobe but that's not very huge.
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
like Sedge said,towel across kitchen top then sink cover and hob glass on top, all heavy stuff at low level, bottles and cans lay flat on towels and cover in towels, check doors for rattles, I use self adhesive draught excluder to stop these. inside ovens and grills can be a major rattle source - again towels and tea -towels help.
dabhand
4,307
23,935
Staffs
Concorde carver E35
Since 1993
My Moho has a slide out bar the straps bottles and glasses in place. Hey, that's rock and roll for ya :D
Chris
21,051
278,586
None
10 years
If your fridge has a lock, don't forget to lock it before you set off.
Many a time in my last van the fridge contents would spew out into the van on the first roundabout we came to.
9,543
32,062
sleights
c class
I suppose a lot top up like we do on sachets of mustard, sauce, mayo etc whenever eating out and keep them in a plastic container in the m/h to save taking bottles.Leaves room for essentials (spare wine)
David
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
Lin has crocheted (probably not how it's spelt, but hey, I'm not perfect), some pockets to put the plates and saucepan lids in.
We also use loads of that rubbery stuff used for non slip matting.
One of the problems we've had with both the vans we've had is a rattling shower door.
In both cases we've found using lengths of foam pipe insulation slipped over the edges has solved the problem
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
sdc77 - what's a 'muggi' ?
We didn't know either - but Googled it & (ignoring the unfortunate Urban Dictionary meaning :giggle:) found this
http://muggi.co.uk/collections/all
Great idea if enough room in your cupboards (y)
887
1,045
essex
Rapido 9090df
20 years (unless you count my dads VW which makes it 52 years with a few gaps!!)
Dogs will be more impressed if you let them sit inside with you rather than towing them:)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
We just get used to the rattling.
When we had an old Veedub we used to use a cheapo hammock to store odds and sods in - makes good use of any spare vertical space.
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
A couple we met talked about a Dutch couples solution, obviously no use if you place heavy objects in an upper locker, nothing will prevent a spill. To prevent rattles and stop lighter objects moving they filled a binsack with air and fastened it off, placing it in the cupboard to fill the remaining space. Yes, not a perfect seal on the bag so some leakage, but they said they had tried it and it did work, stopped done movement and some banging/rattles. I think they used freezer bag plastic clips to provide the seal.
Ed Excel
870
547
Ribble Valley
Coach built
Started 2007
Used to do something similar to the Dutch couple, with our last M/H. Stuffed a partly inflated plastic football in the oven to stop the grill rattling. It had the double benefit of quietening the grill pan.
trekkin
332
490
Staffordshire
Rv
5 years but still learning
Not sure how old your van is but One of the biggest successes and greatest difference for us was having new shock absorbers fitted to the rear, (we had air assisters on the front) this took out a lot of drone and bounce that eliminated lots of the rattles. Reduced som e much noise.
If your van is older why not get then checked, if they need changing you will be amazed at the difference for the sake of a few hundred pound
Happy MoHo ing.
90
189
Wiltshire
A Class Hymer B584
Since 2010
'Single use' supermarket bags around everything. Then re-used as wate bin liners. Otherwise earplugs.
