Tip for buying tyres
Discussion in 'Motorhome Chat' started by TheTwoOfUs, May 27, 2016.
  1. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    I'll start a new thread for this as I don't want it to get lost in my other posts.
    Just bought 3 new Michelin Agilis camping car tyres 215/70Q15 109Q.
    I normally pay £405.
    Checked with Kwik Fit on line, price for 3 tyres, balanced, fitted and filled with nitrogen £300.
    You order and pay on line, select your nearest Kwik Fit centre, book an appointment and they will deliver them there. A saving of over £100 is not to be sniffed at. (y)
    • Informative Informative x 6
    • Useful Useful x 5
    • Like it Like it x 2
    • Thanks Thanks x 2
  2. DavidG58
    DavidG58 Funster
    Feb 24, 2013
    7,184
    14,127
    Bolsover, Derbyshire
    great value, but why three tyres?
  3. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    2 + spare. After my blow out last week I decided to change them as they were same age.
  4. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,950
    I used Kwik Fit Mobile both on the Autoquest a few years ago and on our Burstner in January. £435.92 for four Michelin Agilis Camping fitted on our drive - and the fitter didn't even want a cuppa because he did us first job and had just had his breakfast :D
  5. Photo4x4
    Photo4x4
    Jul 26, 2014
    371
    864
    Scottish Highlands
    ... and neither is the nitrogen! :)
    KH
    • Funny Funny x 9
    • Like it Like it x 3
  6. chaser
    chaser Funster
    Feb 16, 2013
    7,976
    9,039
    uttoxeter
    Now you learn something every day , my sil has his own tyre company, Blythe bridge tyres, plug plug, but this nitrogen thing is new to me , what's that all about.
  7. Bailey58
    Bailey58 Funster Life Member
    Jun 23, 2010
    6,700
    10,394
    Norfolk and Toftir.
    Courtesy of Kwik Fit:
    The facts about nitrogen filled tyres
    • Nitrogen is used in Formula 1 racing, aviation tyres, military vehicles, NASCAR and heavy construction vehicles.
    • Nitrogen maintains tyre pressure 3 to 4 times longer than air-filled tyres and disperses heat more effectively resulting in better fuel economy.
    • Nitrogen delivers longer tread life due to less heat generation.
    • Nitrogen inflated tyres deliver optimum handling characteristics for longer as pressure is more likely to be maintained at the correct level.
    • Nitrogen also slows the chemical ageing of the tyre’s rubber components resulting in fewer tyre failures.
    • Nitrogen results in improved performance, increased safety and lower maintenance.
    • Useful Useful x 3
    • Informative Informative x 2
  8. Speve
    Speve Funster
    Jul 29, 2013
    2,226
    1,898
    Salisbury
    How do you top up the tyre if required?
  9. wingman
    wingman Funster
    Feb 10, 2013
    1,048
    2,631
    Romford, Essex
    RE Nitrogen....
    Interesting post; thanks.
    Question 1. How much more does it cost over ordinary compressed air?
    Question 2. When you DO need to top up, does it have to be nitrogen? Sorry, science wasn't my strong subject (n)
    • Like it Like it x 1
  10. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,953
    3,937
    Corby, Northants
    I would happily challenge some of these claims by Kwickfit.
    The two main application of Nitrogen filled tyres is A, for aircraft, because ordinary compressed air can form ice crystals at high altitudes resulting in the moisture in tyres causing vibration and balance problems when landing.
    B, in motor sport, the elimination of moisture in tyres through the use of pure nitrogen (or dried compressed air) can help reduce tyre temperature when operating in extreme conditions, close to maximum load/speed.
    The AA state
    For passenger car tyres the main claims seem to be:
    • Less corrosion – because unlike air there's no moisture in pure nitrogen
    • Slower rate of pressure loss – nitrogen molecules are larger than oxygen molecules (which make up 21% of compressed air)
    Air loss can occur through the inner liner of the tyre as well through the valve, punctures, or failure of the seal between tyre and wheel rim. Pure nitrogen might leak more slowly through the liner, but you would still have to check tyre condition and pressure regularly.
    Corrosion of the tyre from using normal compressed air is unlikely anyway because only the outer tread band of a car tyre contains steel – the amount of moisture reaching it from the inside is minimal.
    To change to nitrogen you have to have the air already in the tyres removed before the tyres are re-inflated with purified compressed nitrogen. There will be a one-off charge per tyre but once filled with nitrogen, future top-ups would have to be with nitrogen if any advantages are to be maintained.
    Overall, while accepting the possibility of purified nitrogen being of benefit in certain applications, we don't think that the cost and possible inconvenience are justified for normal passenger car use.
    • Informative Informative x 3
  11. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    1. It was included in the price of the tyres.
    2. Yes it does have to be nitrogen. They said just pop back to them if they need topping up.
    • Informative Informative x 1
  12. Abacist
    Abacist Funster
    Oct 15, 2013
    1,308
    1,563
    Devon
    A bit difficult if you are the other side of Europe!
    • Funny Funny x 2
  13. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    Let the nitrogen out and pump up with air if it's that bad.
  14. Dognewf
    Dognewf Funster
    Nov 4, 2015
    246
    190
    Glasgow
    just had 4 tyres same size at kwik fit, same price. best price i could find. van wouldn't fit into depot, too high, and the first fitter said Health and Safety wouldn't let them work outside. manager soon put him right and tyres fitted in their car parking area.great service though, ordered in morning online, had a call from the depot at 4.00 pm saying that was them delivered.
  15. GJH
    Aug 20, 2007
    27,349
    34,950
    The reason I chose the Kwik Fit Mobile service is that our local branches can't fit the van inside and their car parking areas are small. Works well though, no having to take the van to the depot and waiting whilst other jobs are finished and no extra charge (y):)
    • Useful Useful x 1
  16. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,694
    1,494
    West Midlands
    There's a firm called "Black Circles" who run a similar service. You choose a local fitter and they deliver to them for the fitting. It's cheaper than the mainstream tyre depots and they were very helpful when I decided to ring and confirm about the size of motorhome and would it fit in the fitting bay.
    www.blackcircles.com
    Wyn
  17. SuperMike
    SuperMike Funster
    Apr 28, 2010
    1,106
    1,270
    St Albans
    The only place to buy tyres is P & B tyres, members on here @Brian and Jo. They will also deliver and arrange local fitting.
    Super tyres, super prices, super service and, if you arrive at the right time of day, bacon rolls and tea. :)
  18. TheTwoOfUs
    TheTwoOfUs Funster
    Jul 24, 2009
    2,676
    7,472
    South Yorkshire
    Just checked Black Circles and they would have been over £30 dearer for the three tyres.
  19. injebreck99
    injebreck99 Funster
    Dec 5, 2011
    1,256
    1,351
    norfolk
    I worked for Krap-Fit for 6 months, I would not let my worst enemy deal with them, I know things that would open many peoples eyes. There are better things than low prices, believe me.
  20. Yorick
    Yorick Funster
    Oct 1, 2013
    4,110
    6,033
    Lanzarote
    Reliant Robin base van :)
    • Funny Funny x 7
