Tight Nuts
Discussion in 'Tech/Mech General' started by Larrynwin, Feb 23, 2010.
  1. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,065
    14,391
    Norfolk
    Had to change a wheel on the toad today ( puncture ). The wheelbrace 1ft long was useless, I needed a 3ft length of pipe on the end of a socket to move the studs.
    Had I been on the road I would have needed to ring rescue. Those damn air impact wrenches. Will adjust torque on studs and carry socket and bar in future :Eeek:
  2. zaskar
    zaskar Funster
    Sep 25, 2007
    992
    98
    UK
    I found that an axle stand was also very usefull.
    Because the "reach" of the wrench has to be long enough to reach the nuts on rear (twin) wheels, it means that there is a good chance of slipping off the nut and rounding the edges off. Not good.:Blush:
    I used to fit the wrench to a nut and then rest the outer end on to top of an axle stand to prevent this. Take the "tight" off each nut, then jack up the rig and use the axle stand for what it was designed for.:thumb:
    Been there twice! Both times in France in a million gerzillion degrees! Oh joy!
  3. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,991
    1,993
    Warwickshire
    I carry a long square-drive 'breaker-bar' and impact-strength socket to get my nuts off (the Hymer) and a torque wrench to put them back on again. Also very useful for the car if things get a bit stuck.
    Philip
  4. dealgan
    dealgan Read Only Funster
    Oct 23, 2007
    137
    Donegal, Ireland
    Good tip about the axle stand.
    I used that tip, together with a sledge hammer on a breaker bar to get a stuck hub-nut off a car one time :)
    Are there specific torque settings for wheel nuts, or is it simply "damned tight" ?
  5. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    If I can't avoid one of these idiots in a garage with no idea how to use a torque wrench or worse just uses the air gun then it's straight home and undo and retighten properly!
    If at all possible I just take the wheel/s, it limits the overall damage 'they' can do.:Angry:
  6. Dodgey
    Dodgey Funster
    Oct 15, 2007
    1,612
    239
    Gone RVing
    There is a specific torque for every nut and bolt, period.
    Some vehicle hand books will at least have the wheel nut setting but not all leaving 'you' to search it out.
  7. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,382
    18,066
    YO11 2BD
    and if you exceed that torque, especially wheel nuts, it's just as dangerous as not tightening enough.
    most 'windy guns' are torque ajustable and experience will tell the user what setting is right but they just cant be arsed to reset it !!! :Angry:
  8. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,065
    14,391
    Norfolk
    This is only a little Peugeot 107 and I had to stand on a 3ft bar !!!
  9. ruffingitsmoothly
    ruffingitsmoothly Read Only Funster
    Jan 2, 2008
    1,395
    69
    West of Southampton edge
    I have proper stand for the wheel brace a sort of ladder thing
    [​IMG]
    [​IMG]
    Regards Pat
  10. Hayleylulu
    Hayleylulu Banned
    Feb 17, 2008
    5,391
    3,881
    Full timing in the van
    I Get tight nuts when i look at the wife:Rofl1::Rofl1::Rofl1::Rofl1:
  11. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    9,065
    14,391
    Norfolk
    Who's wife :Rofl1::Rofl1:
  12. pneumatician
    pneumatician Read Only Funster
    Feb 22, 2009
    102
    14
    Burntwood Staffs
    It is most unlikely that your wheel nuts or bolts were tightened with an Impact Wrench if fitted in either the factory (definately not), a good tyre fitter or reputable garage. Impact Wrenches can be used to remove fastenings but not to tighten.
    The basic tool is a Hand Torque Wrench but preferably a Pneumatic or Electric Torque controlled Nutrunner, in the factory a Multi Spindle.
    On no account grease or copperslip wheel fastenings the friction is an essential component of the tightening process. Lubricating the fasteners will result in over-tightening resulting in bolt failure. If you have fasteners that you suspect have been overtightened then replace. In production Bolts are now very often tightened to yield and should be replaced once removed.
    The supply of such equipment to the MVI was me job.
    Steve
