Three cables on Negative Terminal? (1 Viewer)
Feb 9, 2008
8,944
18,697
Corby, Northants
Coach Built
Looking for advice. I purchased from new a 2011 Autotrail (Excel670B). The leisure battery has 3 cables going to it's negative terminal. One brown and two black, one of these slightly thicker than the other.
Would I be right in thinking the thickest black is the ground cable to the vehicle chassis, the other black being the link to the second leisure battery to wire them in parallel and the brown one from other services
(Is it possible to confirm this with a multi meter and if so how !)
(As a matter of interest I'm looking to transfer all negative connections less the ground on this battery to a 'shunt' as I will be installing a battery monitor)
Thanks in advance.
funflair
19,305
30,073
Guisborough
MORELO palace
since 2012
Hi Philip I think that the shunt will need to be straight off the -ve terminal before it goes anywhere else.
If the other battery only has one cable from the -ve post you should be able to follow it or get Mena to give it a "tug" it should go straight to the other battery BUT it is never safe to assume these things.
Martin
Feb 22, 2011
9,763
20,120
Newcastle under Lyme
Hymer B544 A Class
Since 2015
No expert but surely leisure battery won't be earthed to chassis will it ?
Isn't that the job of the cab battery ?
andy63
4,672
15,017
south shields
None
since 1990
My Own management panel could be installed in either positive or negative side.. but think as Martin has said one side of shunt needs to come directly off the battery negative...all the other connections to the negative then taken off the other side of the shunt... that ensures all circuits are monitored by the pmp..
Andy
funflair
19,305
30,073
Guisborough
MORELO palace
since 2012
I would be pretty sure the leisure side is grounded to the chassis, if not directly it would it its way via shared charge sources, actually I am sure because I wired a battery top up thing for a friend it went from the leisure batter to the starter battery +ve wire only so must share the common ground -ve.
Martin
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
As Martin has already said.. The -ve side of the leisure battery has to go to a common earth point somewhere.. Might not be where folk would expect it to be but there has to be a connection somewhere !
PhilandMena
Feb 9, 2008
8,944
18,697
Corby, Northants
Coach Built
Thanks, pretty much confirms what I suspected. Just waiting for Monitor to arrive before I fit it and destroy the wiring loom, monitor and both sets of leisure batteries. I'll post again when completed.
Jaws
23,832
72,344
Thetford Norfolk
C class, Chieftain
Bet it all goes swimmingly and you have no probs at all (y)
Feb 22, 2011
9,763
20,120
Hymer B544 A Class
Since 2015
I knew I shouldn't comment on things I don't understand enough about :ROFLMAO:
I'll get back to what I should be doing, working
Oct 8, 2014
1,630
3,009
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
Hi @PhilandMena.
I have just looked at the battery on my Excel 600B and I have two wires going to the Hab Battery negative. One is white/orange, and the other is brown/blue. Looking at the wiring diagram in the manual, it only shows a white/orange, going to Hab negative, with a feed to positive from the EM50.
I fitted a second hab battery, but although I was told by Sargent that there should be a plug on the loom to allow a direct connection, I could not find it, and so just wired it in parallel with the first.
This might be of interest to you, as it clears up what the cable with three fuses on the Positive are for!
Link Removed
John
PhilandMena
Feb 9, 2008
8,944
18,697
Corby, Northants
Coach Built
Hi @PhilandMena.
Link Removed
John
Cheers John, very helpful. I didn't realise the Excels were being produced in 2008. I thought it was 2010 & 2011. I guess my 2011 limited edition (well that's what I call it) is not so limited.
PhilandMena
Feb 9, 2008
8,944
18,697
Corby, Northants
Coach Built
Monitor arrived in post yesterday and after an hour faffing about, extending cables and fixing shunt to wall, I put everything together as per the instructions and,
