Thinking of getting fixed Satellite (1 Viewer)
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Just looking for some opinions on what is the best system to go for i have been looking at the maxview crank up and the camos and camos plus we have one of the systems from aldi but struggle to get signal with small dish in parts of Scotland and as we like to wildcamp not keen on setting up a tripod.
Also can you tell me would i be able to fit this system in the same hole as the status on that works from my wardrobe.
Just so you know we go to France,Germany and Belgium and allthought we dont tend to watch tv when abroad would be nice for the dark nights in this country.
Gerry
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Personally I like the Maxview
if your status is mounted at least 6" away from any wood work or wall. it may fit, you may need to enlarge the hole
I would leave the Status in place and find another location, especialy one were you can see the TV when tuning in:thumb:
lorger
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Hi Geo
Might be a silly question but why does it need to be 6 inches from a wall i assume for the winder handle.
Gerry.
P.S.
Forgot to ask will the coax wiring thats in the van be ok or will i need to upgrade it
lunarman
2,156
2,451
South Glos
since 1994
If the hole for the status is by the wall in the wardrobe and far enough away from the outside wall then you may be able to use a globesat through the roof system
Link Removed
you could couple it with a 12v digibox from maplin
Link Removed
As for the internal coax wiring for the status, I've used it in mine for the satellite down feed, but perceived wisdom will no doubt say that it should be changed.
all the best
Sorry used link from the dark side :Doh:
43,329
49,444
it isnt the internal winder you need to consider, although that needs to be where it'll fit easily, its the dish itself.
maxview recomend something like 100mm from any obstruction when folded down and obviously nothing should stop it rotating when erected.
at least 100mm from the roof edge when folded, and they recommend folding towards the rear for aerodynamic reasons....fold it the other way and it'll blow off:Eeek:
43,329
49,444
Hi Geo
Gerry.
P.S.
its not so much the winder but the bezel/locking mechanism that needs room.
you should replace the existing coax with good quality digital satellite coax.
it isnt expensive.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Laneside
We have the Maxview crankup but please be careful with the 6'' guideline as the folded down dish outsde would overhang the side of your van by a goodly lump when you were travelling.
Much better to make a new hole --after careful consideration so that the raised dish or more to the point the LNB when being rotated does not foul on any roof vents when open or closed
Failings of the Maxview are a feeble braking system that does not prevent the dish from blowing around in strong gusts of wind.
My failing is I can always park the van too close to trees that prevent a signat- must walk around site first compass in hand and feel a prat or observe where the sun is at 10.00am and ensure a clear view in that direction ( in this country at least)
Cheers Alan
scotjimland
2,324
10,053
A Woosh bang
Cheers Alan
Hi Alan
I thought I was the only one to complain about this problem.. I'm glad you agree..
see thread: Link Removed
There are crank ups on the market that are more tolerant to wind, this is not an opinion, I have seen Alden and Camos dishes still in use while my cranky had long ago been put to bed..
The Maxview gives excellent reception and is easy install and use.. shame about the flimsy brake.. :Doh:
jim
madbluemad
Banned
Jan 26, 2008
3,327
239
spain
just looking
since 1980
Hi Alan
I have a Camos Flat Sat Cranky and its the dogs doo da's. I bought it after reading all of the posts on this forum and after speaking and writing to Maxview who werent particularley convincing.
We get great reception and have not had any problems with the dish moving in the wind.
Jim
:Smile:
lorger
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Hi All
Thanks for the replys will do a wee bit more research before i part with cash and like the look of the globesat or camos so it dosent get blown over.
Gerry
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
We had a maxview crank up on our caravan a few moons ago - reception was good - not always easy to find the satellites - whilst they have degrees marked on the system it is only accurate if the van is totally level. The biggest negative though was wind (not mine before pappajohn gets hold of it) the slightest wind would cause it to rock and make an intrusive noise and the stronger the wind the greater the noise until you would be forced to wind it down. Fair play to Maxview I sent it back and having examined it when it was 4 years old they said it was not up to standard and should not be knocking and replaced all the bearings afterwards it was better but not perfect - on our 5 er we have had an auto Camos square dish fitted as that was promised to give a far better picture and not to rattle in the wind - it is perfect - no noise - good signal and very little degradation in the rain . Would I have a Maxview again - no I think there are better ones out there now but at 60 cm dish it would give signals where others might not.
RoadProAndy
10
Peckham, in London
11 years
Camos crank-up
Good to hear that Landy Lover is pleased with the Camos crank-up. There is a Camos model we call the "Plus" which has a bigger dish than the standard model and which can be skewed which gives better performance into Spain and other southern areas of Europe. In fact, although I haven't tested it (yet), I expect it to give just as or almost as good performance as a regular 60cm dish system.
RoadProAndy (from RoadPro)
43,329
49,444
The biggest negative though was wind (not mine before pappajohn gets hold of it) the slightest wind would cause it to rock and make an intrusive noise and the stronger the wind the greater the noise until you would be forced to wind it down..
think you're mistaking me for scotjimland, landy.:Doh:::bigsmile:
no problem with mine mate.:thumb:
haganap
12,759
26,447
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I have a maxview semiauto dish if your interested in purchasing it, I am getting a camos dome tomorrow.
dshague
996
302
VAN CONVERSION
20 years
after reading all the threads on the subject of dishes ,i went for the camos plus .
there was only one space it would fit on the roof when in fold down ,so double check were to fit it .if it did fit in the hole in wardrobe will you beable to yo turn handle when it is full of the boss clothes .the maplin box will also work with any dish its nice and small and will hide away somewhere .one thing to think about is can you reach to the inside roof of you van were it is to be fitted to reach Handel .
lorger
lorger
9,661
90,507
Dumfries
Knaus Sun 650MEG
Thanks again everyone thinging more with the camos or plus now will have a good look at them over coming weeks and see if i can see a fitted one.
Gerry
