Thetford toilet door key (1 Viewer)
Oct 3, 2012
170
125
Hastings
Since Oct 2012
I have just changed my thetford door 3 toilet access hatch as it was leaking, The new door comes with a new key, I want to take the barrel out of the original door and put it in new so my keys match the rest of the van, Anyone know how?
Terry
11,904
8,969
Lincolnshire
Can't remember ;)
Hi they fasten with a nut on the inside or poss a spring clip -simply undo the nut and pull out -:thumb: forgot they also have a possi screw to hold the lever in place you may have to undo that as well but doubt it
terry
Scottyboy
Oct 3, 2012
170
125
Hastings
Since Oct 2012
Lol, just been out and changes it, 5 min jobI thought I read a post a while ago about needing a special red key? Perhaps that was for something different.
Tootles
Sep 14, 2013
9,511
34,799
Lancaster
Was a newbie, now a Middie.
Check along the barrel of the lock itself. There should be a small hole. Push into this with a thin screwdriver, or a thick pin, and the lock mechanism will slide out forwards. Don't worry, it wont fall apart, (unless previously damaged). Carry out the procedure on the new lock, line up the pin with the hole in the case, and slide in. :thumb:
