thetford toilet casset (1 Viewer)
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
does anyone know how to change the lip seal on a c 250 casset also where would i buy a running light lens for a hymer silverline 562 any thoughts appreciated
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
thanks for that Techno100 mine is a c250 which is a bit different on the top are they all the same principle as i have done one before do they all have the screws under the 2 parralel strips
Oct 20, 2010
2,248
37,616
Burry Port South Wales
Since 2003
If you take the slider out of the top off the seal, half slide it in from the opposite side so you can use it as a lever, on the top edge of the top round section there are two little arrows marked near the edge, using the slider as a lever rotate the round top section thru about 10 deg to the next arrow. the whole top section will then come out. You may need to tap the round section lightly to break the seal to get it to rotate. (y)
gpz
gpz
May 24, 2012
255
34
north yorkshire
converted movano
newbie
thanks very much i looked at the arrows but did not want to attempt it till i found out thanks again
