Thetford Locker Door
Discussion in 'Tech/Mech General' started by Drexxer, Jan 14, 2015.
  1. Drexxer
    Drexxer Funster
    Oct 26, 2014
    257
    281
    Lincolnshire
    Hi all,
    the locker door on our MH, 465mm x 1035mm only has 1 key lock in the bottom middle though has a latch at each bottom corner, one of these is broken and it gives you a start so that you can Ebay 009.jpg prise the door open, even if it wasn't broke you only have to push the button in and the corner is slightly open and I'm wondering if I can replace it with a more secure locker frame?, twin lock or even triple lock
    Andy
  2. Blondi
    Blondi Funster
    Jul 27, 2007
    165
    68
    West Yorks occasionally
    You're right, I was concerned about security on my door with only 1 central lock. You can buy the separate corner buttons which have key barrels, but what I have been unable to buy are the concentric springs which fit behind the buttons (they are different to the springs behind the plain buttons). I have reshaped an existing spring with some difficulty, but the only source of the proper spring seems to be if you buy a complete door.
    If anybody knows of a source of these springs I would love to find out.
    Pete
    • Like Like x 1
  3. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,327
    34,794
    Easiest to fit would probably be one of the security locks made by Milenco or Fiamma. Some are fitted by drilling through the wall and some onto the frame, it all depends what is behind the wall. The two different makes are of different patterns so it pays to make up a contour template before buying.
    • Like Like x 1
  4. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    • Like Like x 1
  5. Techno
    Jul 28, 2010
    14,182
    14,954
  6. Peter A Forbes
    Peter A Forbes Funster
    Nov 23, 2014
    261
    182
    Rushden, Northants, UK
    • Like Like x 1
  7. Drexxer
    Drexxer Funster
    Oct 26, 2014
    257
    281
    Lincolnshire
    Thank you for the reply's, It's the striking plate on the fixed part of the frame for the corner button that is broke on our's so when I get 5 minutes I will compare the button striking plate with the key lock plate and come up with a plan,
    I know it's never going to be Fort Knox but hopefully a bit better than standard
    Andy
