Thetford fridge (1 Viewer)
Jan 18, 2010
538
138
Airdrie Scotland
6 years and 20 years as a tugger
My fridge freezer over the years has been in and out of the dealers for repair it has got to the position that when I wake up the first thing I check for is a flashing blue light as I don't wild camp and use sites with Electric I'm thinking for next year just to buy a domestic fridge fridge freezer and put the thetford in the garage has anyone done this is there any pitfalls
Bill
43,301
49,289
is that 'domestic' as in household, or as in dometic....a simple typo ?
cant see any real reason, apart from the compressor noise, not to fit a household fridge freezer if you can find one to fit.
i believe VWAlan uses this type in his 5th whee.
and if the current fridge is unreliable i would just dispose of itl.
sticking it in the garage is using payload for nothing.
B
Jan 18, 2010
538
138
Airdrie Scotland
i believe VWAlan uses this type in his 5th wheel.
Yes a household fridge freezer if I can get one to fit height and depth no problem it's the width I could struggle to find I'm now at the stage where I have no confidence in this fridge when you consider it's hardly used and I would suggest if you are in the market for a motor home avoid ones with Thetford fridges . The amount of people I have spoken to on sites and on forums who have had the same problem it's ridiculous and Thetford know about it
Bill
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
We have had a 12v element on ours after 3 years, apart from that we've had no problems.
Having said that, we haven't used hookup apart from when we are parked at home, chilling the fridge in preparation for a trip.
Are you SURE you want to replace the fridge with a domestic one? How will your food keep chilled en-route? If you have no confidence in your Thetford why not buy a Dometic unit instead?
B
Jan 18, 2010
538
138
Airdrie Scotland
Your fortunate you don't use electricity a lot if you did you would certainly have to have the 240 volt heater element replaced after a certain amount of use if you google your fridge you will see the problems people are having also the price of a Dometic fridge is ridiculous just back from Currys a slim Samsong half fridge half freezer £229.00 compare to a Dometic £680.00 Also if you switch on your domestic fridge the day before you leave it will keep everything Perfect until you arrive on site
Bill
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
Hi Dometec and Thretford are the same company's I belive :Smile:
You can use household fridges,some self builders have used them for yrs.
You can use them with inverter suplied from leisure batt that gets charged via split relay from engine then plug into leccy when you arive
Not sure on how far out of level they will work at but 3 way ones don't go that far out of level anyway:Smile:
Provided you keep the door shut household F/F will keep stuff frozen for 24 hrs
Terry
B
Jan 18, 2010
538
138
Airdrie Scotland
Terry
Thanks I checked domestic ones at Currys they do a slimline 50cm that will be perfect Also has a 50% fridge and 50% freezer and a lot more room and as you say keep the door closed and it will last for 24 hours and it comes with a 5 year warranty
Bill
TheBig1
17,600
43,041
dont forget you will have to adapt and make securing brackets for a domestic fridge, possibly invalidating the warranty.
the thetford fridge is no different in principle to the newer dometic, who now own thetford name. however the newest versions are far superior in design and control but with more to go wrong
if it was me, i would take the fridge out and get it reconditioned. there really is very little to go wrong with them. if it keeps burning out elements, change the thermostat too. clean the flue thoroughly and ensure the gas and fluid are combined by inverting the fridge for 12hours. if this is beyond you have a mobile engineer do it for you. much cheaper than a replacement
Terry
11,929
9,044
Lincolnshire
Can't remember ;)
::bigsmile: you will probably get more for the second hand 3 way than the new domestic one costs :Smile: if it was me I'd save it and fit it back into the van come sales time :thumb:I still have a old glass in the cnr to see if lit knocking around somewhere , mate used it temporary when he moved houses :Smile:
Terry
B
Jan 18, 2010
538
138
Airdrie Scotland
Inverting the fridge aaaaaa what does that mean
TheBig1
17,600
43,041
posh word meaning turn the bloody thing upside down:ROFLMAO:
beating it with a rolled up copy of MMM dated 1970 is of course optional:ROFLMAO:
