Thetford 'fridge
Discussion in 'Top Tips & Tricks' started by janeerica, May 3, 2015.
  1. janeerica
    janeerica Read Only Funster
    Jun 15, 2014
    9
    17
    Godalmig
    My Thetford N100 SES fridge has autoselect between power sources - it works fine on 12v and mains, but gas fails to ignite. Plenty of gas and it is turned on! I should be grateful for any suggestions as to what might cause this. I haven't yet found the ignitor or thermocouple location either. Thanks in advance. Regards Brian
  2. Reallyretired
    Reallyretired Funster
    Apr 27, 2008
    5,960
    3,406
    Eastbourne East Sussex
    Mine behaves eccentrically sometimes, usually if it has not been on gas for a while. The gas seems to select automatically but doesn't light.
    Setting it manually to gas operation gets it going, and after a while it can be turned back to auto and will work as intended. No idea why it does it but I just live with it.
  3. WillH
    WillH Funster
    Feb 9, 2008
    1,749
    1,471
    SW Scotland
    My auto Thetford fridge is now a manual fridge, works fine, no hassle, and I get to choose the energy source. Just been on gas for the best part of two weeks..
  4. CWH
    CWH Funster Life Member
    Jan 29, 2014
    3,115
    13,626
    under a wand'rin' star
    Finally got ours sorted.
    Park up. Engine off. Wait. it takes a bit of time to decide its safe to ignite.
    Then once the gas symbol starts flashing (or occasionally it goes on full-time), the triangular warning light is also flashing - press this and hey presto, it ignites.
    Hope this works for you also.
    EDIT sorry, just realised ours is a Dometic.
  5. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,807
    1,027
    Cark, Cumbria
    Have you got it sorted?
    Does it work in manual/gas?
    Can you hear the igniter ticking?
    BTW there is no thermocouple on ours, it uses the igniter electrode as a thermocouple.
  6. iceni
    iceni Read Only Funster
    Dec 3, 2007
    301
    115
    Birmingham
    Bear in mind that the gas wont light for 15mins if you have run the engine. Just in case the reason you have stopped is because your filling up with fuel :)
    • Like it Like it x 1
  7. geoffrey brooke
    geoffrey brooke Read Only Funster
    May 9, 2015
    United Kingdom
    same problem with our thetford...had to replace the electronic circuit board...ball ache as you have to remove fridge...thetford customer service useless
  8. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,761
    23,214
    Narrfoook
    You are right there.. absolute waste of space the lot of 'em
  9. janeerica
    Jun 15, 2014
    9
    17
    Godalmig
    Thank you all for your advice. Somehow I've managed to get going - cleaned the jets and fiddled around and hey presto, a working 'fridge. Help much appreciated.
    • Like it Like it x 3
Similar Threads
  1. Hettie's Crew
    1,040
