thetford fridge fan
Discussion in 'Fridges & Ovens' started by POWERPLUS, Dec 7, 2015.
  1. POWERPLUS
    POWERPLUS Read Only Funster
    Dec 7, 2015
    5
    armacao de pera
    hi i have been reading about you guys fitting computer fans to the top grill outside
    i recently did mine with 2 120mm fans and a digital thermostat
    i have set the temperature to be controlled at 32c to 35c
    here in portugal the the thermostat is working fine and holding the temperature fine
    before i left home i checked the temperature at the back of the fridge without the fans and it was 51C
    and i originally had 1 fan and this struggled to bring the temperature down below 32c so i added a second fan
    thetford do make a fan kit but the fan is very small so i cannot see it working that well
    i am wandering if there is a recommended temperature for this
    barry
  2. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    5,824
    10,747
    East Sussex
    A Dometic engineer told me to set a fan to cut in at 25 deg
  3. Don Quixote
    Don Quixote Funster
    Jul 29, 2012
    2,503
    3,705
    Lost in La Mancha, Spain
    I would have thought this time of the year you should not need the fan on.
    We have the thetford fridge and it works fine here in Spain at this time of the year with fans off and we only really them as and when needed from May to Sept each year.
  4. scotjimland
    Jul 25, 2007
    28,936
    25,589
    Also did a DIY install.. 2 x 120mm fans with a thermistor that cuts the fans in at around 25c.. and I also fitted a off/ man/auto switch.. but to be honest, I prefer just switching on and off as required.. and as Don said.. shouldn't need it this time of year..
  5. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,182
    14,954
    Leeds the one up North
    Purpose made unit comes in at 50c plus or minus 10%
    image.jpeg V
    • Like Like x 1
  6. tonka
    tonka Funster Life Member
    Jul 2, 2008
    5,435
    7,724
    Does anyone have a pic showing best location of where to place these fans ??
    Our fridge is S*^% once we get to Spain or anywhere warmer than Stratford..
  7. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,535
    5,623
    West Sussex
    I set mine to 35 deg with a 5 deg hysteresis , I find it comes on when the outside air temperature is 25 deg find it just right. However the set temperature will vary depending on the installation and the position of the sensor, I mounted my sensor on an alloy plate between the fans.
    For fitting the fans use cable ties to attach them to the inside of the top vent.
  8. Lenny HB
    Lenny HB Funster
    Oct 18, 2007
    5,535
    5,623
    West Sussex
    • Like Like x 2
  9. Neckender
    Neckender Funster
    Oct 15, 2007
    1,048
    1,305
    Stoke on Trent or Benidorm
    I fitted my twin fans to the top louver with right angle brackets which I gently squeezed in my vice until I got the angle I needed then fitted to top louver with a couple of self tappers.
    John.
