Thetford flush not working (1 Viewer)
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Bailey Approach 740 SE
I think it's the push button that has failed , where to source and are they easy to DIY fit ? Cheers . Bailey 740 SE Approach btw .
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
It was working intermittently and has now stopped all together so I didn't think that sounded like a fuse .
If you pressed it hard it worked and now doesn't work at all so suspected the button .
icantremember
8,325
17,534
Near to Watton in Norfolk
Hymer T-SL668
since 2005
If you have pressed it too hard then the little circuit board has probably come away behind the button ... if you pull the face plate away you will be able to click it back together.
Feb 24, 2013
13,034
101,351
Bolsover, Derbyshire
Hymer S800
not long enough
we had the same on our A class, so a different configuration, but our flush pipe, connected to the fresh water tank, was touching the bodywork, moved it and not had same problem since
does yours have a separate flush tank? If it does might that pink flush stuff help? If fed from your water tank look for the same issue we had maybe
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Had a look at the piping as I dont think the actual holding tank froze , the pipe is clear with prob a 1 cm ish bore . It comes down from the holding tank and spirals round to the outlet to the toilet bowl . I think this maybe the freeze point . Space is tight to lag it , any thoughts or recommendations? Cheers , it's a C260 btw .
Feb 24, 2013
13,034
101,351
Hymer S800
not long enough
no idea on the lagging options, but a word of warning, on our caravan years ago the toilet flush holding tank pipe work froze and split, I had drained everything down and forgot about that tank :(
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Thanks for the heads up , thaw has occurred and no splits in pipework , I always drain everything down .
Mr B
990
1,889
Yorkshire
Rapido 7065ff Design Edit
Since 2015.......
Happened to our Swift Challenger. Turned out to be condensation around the push button. I carefully removed the plastic panel/button assembley and gave it a good clean with some electrical spray. Worked fine after that :)
Adbt
Adbt
Banned
May 19, 2015
673
1,018
Cheshire
Would Elsan Antifreeze in the flush tank be a solution do you think ?
May 31, 2015
11,618
44,215
Cornwall
Ducato PVC
Getting Better
Try and pack in some loft insulation maybe, or expanding foam and hope you never get a leak afterwards...:D2
