Thetford 250, replace or repair (1 Viewer)
Duztee
18
27
Nagykoros, Hungary
c class
newbie
So from reading the web it appears my Thetford 250 is (probably) the worst designed toilet possible.
Prone to corrosion and electrical issues.
Can anyone recommend either a good man to repair and service my non working item, or, can anyone recommend a better make as a replacement.
icantremember
8,318
17,527
Near to Watton in Norfolk
Hymer T-SL668
since 2005
All depends on what is wrong with it ... a little more info would help!
We had a 250 in our last moho for almost seven years with no problem and have the same in our new one.(y)
Jan 22, 2013
1,248
58,450
London SE
A class Adria vision I707
since 1971
likewise ours is eight years old and works fine, I might replace the seals this winter but that's only pre cautionary as they are still working fine,
TheBig1
17,509
42,755
the common electrical fault on them is the switch panel fails. the part can be bought for about ÂŁ40 if you shop around and it takes a couple of minutes to fit with no tools required
Duztee
Duztee
18
27
Nagykoros, Hungary
c class
newbie
Great! so the only replies are from people who want to tell me how great theirs are!
Not exactly what I asked for.
But for icantremember the contacts on the small circuit board which detects the level are corroded away, same for the fuse spades. since the van is only 4 years old there is obviously a condensation problem which needs sorting before bothering to replace the corroded parts, hence my asking for recommendations of someone who knows a lot more about this thing than me.
icantremember
8,318
17,527
Hymer T-SL668
since 2005
If those are the only problems I would sort it not change it.
Spare parts are easily available in the UK and most of Europe.
Although my level indicators work fine, I only ever rely on a visual check through the flap when open and empty every day however full if possible.
I don't know why you are getting condensation in the cassette locker ... it could be that the cassette has been replaced after emptying in a wet condition .... could be cured by introducing ventilation to the locker.
Jan 8, 2013
8,478
11,516
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Perhaps by now you should have realised that these toilets are not a problem for most people.:banghead:
Its not the worst toilet in the world and you have just been unlucky.
We have all been wasting our time trying to help - What a waste of time - Cheerio and good luck!:swear2:
