thetfod toilet probs
Discussion in 'Tech/Mech General' started by semi hemi, Nov 27, 2011.
  1. semi hemi
    semi hemi Read Only Funster
    Sep 26, 2011
    27
    4
    leicestershire
    hi all i've got a poblem with the toilet in my motohome,its all ok apart fom the flush,when you press the flush button nothing happens,the lights dim so i think the electric motor has seized,now the problem is that i cant see how to get to the motor,is there any easy way to get it out?is it a common fault with them?i have tried to get to it through the cassette side but cant even see it and the toilet side is sealed..any one know?
    thanks in advance.
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    depends on which toilet it is as some are fed from the main water tank others have a separate flush tank.
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,340
    7,462
    Nr Watton in Norfolk
    It depends on your model.......ours is the C250 and draws the flush from the main tank.
    To access the pump you have to remove the complete seat and you can see it built into the back of the pan.
  4. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
    im not sure what model it is,the van is 1984 so if its the original toilet then its an early one,there is a pull out resevoir thing that you can put liquids in would that be the flush supply?
    im not much help am i:RollEyes:
  5. icantremember
    Sep 2, 2010
    5,340
    7,462
    It is a different model to ours, the C250 has only been around for 3 or 4 years. Another moel has a toilet roll holder recessed into the unit which has to be removed to get the pump.
    The swing out filler is for topping-up water and fluid into the dedicated toilet resevoir.
  6. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
    yep thats the one,i've just been out and pulled the toilet roll holder out and there it is!!! easy when you know how..Thank you very much i can start working on it now..
    cheers all
  7. wivvy's dad
    wivvy's dad Read Only Funster
    Jun 22, 2010
    3,218
    1,807
    48.066895,12.862673
    When you press the flush button, does the motor whizz?
    If yes, but no water flushes, then it needs topping up with water.
    If no, then the pump motor is FUBAR'd
    Given the age, it's probably a C2
  8. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
    nope no motor noise at all and the lights dim when you press the button so im thinking the motor has seized...just hoping i can get a new motor.
  9. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,341
    5,353
    East Sussex 01-580-881288
  10. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
  11. 1Oll
    1Oll Read Only Funster
    Jan 12, 2010
    175
    86
    Cheshire
    Thetford Site
    The Thetford site has all the exploded drawing and lots of info.
    http://www.thetford.com/
    Regards Brian.
  12. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
    great stuff,thanks
  13. semi hemi
    Sep 26, 2011
    27
    4
    leicestershire
    well i managed to get the motor out and it was seized possibly from lack of use,i managed to turn the spindle and free it off and now i have a flushing toilet(dont know for how long though)so thanks for all the replies and i now know where to get a new one if it doesn't last..
    many thanks
  14. icantremember
    Sep 2, 2010
    5,340
    7,462
    Well done:thumb:.........I suppose you are now flushed with success:Wink:
