The Thetford Toilet
Discussion in 'The Beginner' started by Adria 5, Sep 1, 2007.
  1. Adria 5
    Adria 5 Read Only Funster
    Jul 23, 2007
    1,197
    4
    hi the smelly job!:RollEyes:
    You will need the right chemical for which the site allows !! perhaps member could put the one they use and price per litre..
    put some chemical in the toilet measured amount with a drop off water! in the spout thetford say..
    [DO NOT pour Aqua Kem into the holding tank through the blade hole: always add it via the pouring spout. ]
    then to empty after !!!:Wink:
    Take to chemical waste area! find this when you arrive on site!:wub: mind you dont lose your cap down the waste hole ! empty and wash out with water a couple off times add the chemical again has before..!!1
    if winter and laying up keep empty
    Ray
    ray
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    thetford recommend 130ml chemical with 2 ltr water for the blackwater tank. i use thetford blue and aquarinse pink in the flush tank.
    as for the site preferences if they allow chemicals then it shouldn't matter what type/make hence the term "chemical toilet disposal".
    i find it's only the 'green' sites that dont allow formaldahyde ect.
    john
  3. gillr49
    gillr49 Read Only Funster
    Aug 8, 2007
    334
    4
    Holbeach Lincolnshire
    More tips, really useful
    Why not put the chemical through the blade hole? No reason for asking I've just got a curious nature.
    How to ...............level with chocks, get ventilation at night and be safe and anything else I haven't even thought of (next week will be too late)
    :rofl::rofl::rofl::rofl:
  4. Adria 5
    Jul 23, 2007
    1,197
    4
  5. pappajohn
    Aug 26, 2007
    30,263
    17,930
    YO11 2BD
    hi gill, i think suraman hit the nail on the head but i'm sure you could use a little more detail.
    leveling: park in prefered spot and look at van. whichever end/side is lowest put ramps under the lowest wheels, CAREFULLY drive up ramps then look again. it only goes bump if you drive over the top!!! if at top of ramp but still not level move elsewhere leveller and repeat til level. you will see when its level enough. dont forget to chock wheels and put on handbrake/leave in gear.
    ventilation: open windows onto first position catch which should give about 10mm opening. open roof lights in same way.you could always stand something against the blinds which will fall if the window is opened ie: a pan or walking stick ect. we never have a problem with this as it looks like windows are closed.
    the toilet chemical probably damages the sealing face of the blade but inside the tank it wont matter.
    john.
    • Like it Like it x 1
  6. gillr49
    Aug 8, 2007
    334
    4
    :Smile::Smile::Smile:Great John
    Thanks for that. I bet to you guys these things are second nature, hopefully they will be to us soon.
    :Smile:
  7. Adria 5
    Jul 23, 2007
    1,197
    4
    hi no problem :Smile: every one starts somewhere that what i started the posts for to help new people out !!! I like the mh enjoy:Smile::Smile:
    RAY
  8. Elaine Downes
    Elaine Downes Deleted User
    Leveling
    I find if you roll out of bed...your not level:Rofl1:
  9. RockieRV
    RockieRV Deleted User
    Also:
    'Never use household detergents to clean the toilet: they may contain bleach, which can cause damage to the seals and plastic. Use a dilute warm water solution of washing up liquid.
    If you won't be using the thetford for some time, give the toilet a thorough clean, making certain that you dry both the lipseal and blade, then spray them lightly with Thetford Maintenance Spray. Leave the blade in the open position to minimise the risk of the seal sticking to it.
    DO NOT shake the holding tank violently when rinsing it, as this can dislodge the float arm. A gentle swirling action and two or more rinses, as required, will ensure the tank is thoroughly clean.
    When charging the holding tank add two litres of water to the Aqua Kem. This minimises the risk of waste "Pyramiding".
    Add Aqua Rinse to units which have their own fresh water tanks, It ensures a better flush flush preventing staining. '
  10. 2escapees
    2escapees Deleted User
    The simple and best solution for your Thetford is NOT to use any chemicals but have a Zog fitted. Saves money, good for the environment and NO smells!
  11. American Dream
    Aug 20, 2007
    6,489
    154
    Lincoln
    And there was me wondering why my Tea was Pink and Fragrant.
    Thought it was some exotic blend.:RollEyes:
    Still I don't seem to be suffering from any after effects.
    [​IMG][​IMG][​IMG]
  12. keith
    keith Funster
    Aug 25, 2007
    3,289
    1,674
    Ecclefechan
    Except when emptying.
    A Sog only keeps smells out of your van (which is good) :BigGrin:
    We have used Bio Magic for the last 2 years, in USRV & Euro van & found it to be good at doing what it says, no chemicals so no problems with sites that say no chemicals.
  13. freakylady
    freakylady <font color="red"><B>Quiz Champ</B></font>
    Apr 1, 2008
    68
    please will you clarify this for me ... before toilet is used you need the chemical PLUS 2ltr water in the Thetford unit?
    we have one of the larger units and are currently putting in about 180mls thetford blue to stop any smells.
  14. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Oh my .... i never knew going to the bog could be so complex:Eeek::Rofl1:
    Thank the Lord ive got an RV with a proper flushing loo and the best waste disposal system ive ever seen.:thumb:
    Why cant European manufacturers fit a proper flushing loo and holding tank system :Doh: It really is a no brainer :thumb:
    No doubt in 10-15 years time we will have caught up and decent loos will be fitted as standard then we will all look back and laugh :Laughing: wondering why we put up with it for so long!! :Rofl1:
  15. vicdicdoc
    vicdicdoc Read Only Funster
    Sep 25, 2007
    120
    North Wales
    Better still if its a SOG :Wink:
  16. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,841
    9,107
    Tropical Bar,Benidorm.
    Hi Freakylady
    Yes you do, you need enough water in the tank to cover any waste, otherwise its going to get rather smelly no matter which additive you use.
