The pressure is getting to me! (1 Viewer)
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi There all you experienced MH’s I'm looking for a easy to use reliable tyre pressure gauge, digital or analog is fine. All the ones I've seen on reviews are for cars and don't go high enough.
Any thoughts anyone?
Many thanks Tony
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Since 2015
I bought a digital tyre pressure gauge form Halfords. it is this one and works a treat.
Link Removed
Hope the link works!
Brakers
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi there thanks for the link it looks a bit dumpy to me do you have to remove the wheel trim to use it?
Many thanks Tony
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Link Removed
I cannot seem to find the following info.
1) Is the read out switchable ( PSI, atmospheres, kg etc )
2) what is the upper limit of what it can read ?
3) is it in any way water resistant ?
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Since 2015
I haven't found it a problem. I use it on 16" standard wheels with the trim on with the steel valves. I also have tyre pressure sensors so I have set the pressure with this device and monitor the pressure in the cab. Works well as does the pressure alarm if you set it to low!
Teuchter
Nov 4, 2014
1,404
4,001
Lee on the Solent
Hymer Mercedes MLI 580
I have been caravanning for 32 years but in 2014 I have"gone over to the dark side"
Try this one from Amazon - less than £10! :)
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Since 2015
Click on the more info but here it is!
Halfords Digital Tyre Pressure / Tread Gauge Extra Info
  • Operation Range: 5~99psi / 0.35 ~6.85bar / 35 ~ 685kpa / 0.4~ 7.00 Kg/cm2
  • Depth: 0-15mm / 0-19/32inch
  • Activation Pressure: >5 psi / 0.35bar / 35kpa / 0.4 Kg/cm2
  • Measurement Units: PSI / BAR / KPA /Kg/cm2 / inch/mm
  • Display type: Positive LCD
  • Display format: 8.8/.8.8 PSI / BAR/ KPA/ Kg/cm2 /inch/mm
  • Uses 1 x CR2032 battery (included)
Jaws
23,836
72,443
Thetford Norfolk
C class, Chieftain
Perfect ! I have a ten quid voucher from Halfrauds ( had to return some camping cooking pots that all the paint came off on first use ! ) so will pop down and get one
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
Can I jump in on this thread and ask what people use to pump their tyres up if they are a bit low or is it a trip to the garage? I'm suire I saw a thread on here recommending a pump but I can't seem to find it with the search and my "michelin" pump from Halfords only goes up to 50psi (or so it claims but not sure that I want to try it...)
Feb 13, 2013
992
1,084
Edinburgh
Rapido 881F
Since 2015
I use Morrisons air line which goes up to 90 PSI I think but beware not garage forecourt airlines do!
Abacist
3,726
10,647
Devon
N & B Arto 88F Tag
since 2013
I bought one of these which has a pressure gauge and is more than powerful enough to pump up camper van tyres to over 80psi. At £50 its a bargain. Don't buy a double barrelled pneumatic pump as they are not man enough for the job.
Bacchus
412
4,236
Staines
A Class Hymer
since 2011
One of these what....?
I saw some double-barrelled foot-pumps in makro; they have a gauge that goes up to 99psi but I can't see them surving my big fat feet for long (c: I might get one for the push-bike.
Jul 29, 2013
9,069
18,482
Salisbury
Hymer B678DL A class
since 2011
I bought one from Maplins It works well and on offer at present.
Link Removed
Aug 26, 2008
4,760
24,924
B&NES
Van Conversion
since 2007
Had mine for couple of years now still going strong(y)(y)(y)
SNAP!!
The only problem was a blown fuse on the 12v socket the first time I plugged the pump in.
