Not exactly laboratory conditions, but..
over all braking % figures without servo were very slightly less than with the servo, it is my considered opinion that in an emergency panic situation theunservo,d brakes would stop the vehicle,in the event of a servo failure, even front wheel lock out was obtained without to much pressure being applied, pressurereqdwas approx 2 to 3 times greater and IMHO easily obtainable by the brake overrun system
vehicles with rear disc's as opposed to drums did not perform quite so well on theunservo'drears and were borderline but passable
Geo
Paul, if the Yanks use Recovery Dolly's it must beok:thumb:
In the case of two vehicles hooked solidly together, .
thats the point tony......they arent linked solidly (unless its unbraked)
the hitch has a sliding head albeit only a few inches of movement.
if they are both travelling at 50kph and the tow car stops the towed (toad) car will still be doing 50kph until the hitch has used up all the free travel in the sliding hitch head then the impact on the tow car will be greater than the mass of the toad which in my book is g force.
just the same as your body hitting the seatbelt in a frontal accident.
push yourself into the seatbelt...it dont hurt.
now try hitting a solid object at 50kph and see if the seatbelt hurts.
