The Genny is alive!!!!
Discussion in 'American RV's' started by kex66, Feb 23, 2012.
  1. kex66
    kex66 Read Only Funster
    Jan 29, 2012
    166
    202
    cheshire
    A Massive thank you to everyone who has given advice on my generator problems this week[​IMG]
    I finally got the bl***y thing going this afternoon.
    To cut a very long story short, I printed off everyones advice from here and RVOC and set off to the RV. I patiently went through all the points but still no luck (No voltage at the genny at all). Then went back and tried everything again but still nothing.
    I then resorted to my plan "B", hitting the ground with a large stick for 5 minutes in the style of Basil Fawlty, while shouting all manner of profanities[​IMG]
    Incredibly, that didn't work either. So before leaving defeated, I went back to the house battery and removed the battery leads one last time to make sure the terminals were spotless. As I was using some wire wool on the positive terminal from the generator, it came away in my hand with a couple of inches of cable.
    Not sure how the cable became broke but the outer sleeve must have been holding it in place and I disturbed it when I took off the old batteries.
    Got under the RV and removed the whole cable (About 3m), took the lot to a local garage and they made a new one up for £20 and threw in cable ties.
    It took me about 20 minutes to fit and the Generator started first time[​IMG]
    • Like Like x 5
  2. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,974
    381
    Rochester
    10 out of 10 for percy verance:thumb:
    • Like Like x 1
  3. upmarkethippy
    upmarkethippy Read Only Funster
    Feb 25, 2008
    364
    81
    Hull
    Very glad to here you have got it sorted.... well done for 'sticking' with it!!
    Cheyne
    • Like Like x 1
  4. JJ
    JJ Funster
    May 1, 2008
    14,662
    26,029
    Excellent news... I am really pleased for you...
    Not only do you now have a working generator but you also have all that accumulated knowledge that will serve you in good stead in the future...
    Well done...
    JJ :Cool:
    ps... my Hymer loo is not holding water again (and thus not forming an air tight seal from the holding tank)...
    Last time this happened I spent over a hundred pounds on a new part and stripped the loo out to fit it...
    ...this time I will fix the problem in ten minutes (max) with a bit of (especially made for the job by me) bent aluminium and the knowledge I gained from the first repair... :thumb:
    • Like Like x 1
  5. madbluemad
    madbluemad
    Jan 26, 2008
    3,341
    243
    spain
    Great stuff. Everybody needs a bit of success every now and again.
    Jim
    :thumb:
    • Like Like x 1
  6. DESCO
    DESCO Read Only Funster
    Mar 11, 2009
    2,651
    267
    London
    Well done persistence pays off.
    The only other case I saw of this was on a company car, that kept cutting out it turned out to be a break in a lead, how the mech. found it he said he was getting annoyed and gave the lead a tug and about 8ins of conductor came out in his hand. On splitting the insulation it looked a fault in manufacture and 2 bits of wire had been joined in the sleeving. It had worked fine for 2 years
    • Like Like x 1
  7. slobadoberbob
    slobadoberbob Read Only Funster
    Jun 1, 2009
    6,159
    1,970
    Kent, garden of England
    pleased it is sorted
    Pleased to hear it is sorted out now.. good feeling when you resolve an issue.. Genny issues are often lead related.. earth or power in some form.. the fact it was running before the battery change it had to be that area.. so pleased it got resolved and you are up and running again.
    Bob
    • Like Like x 1
  8. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,710
    17,328
    YO11 2BD
    result :thumb:
    when i did breakdown recovery we found this a lot on engine braided earth straps which are usually tinned copper wire.....the earth strap looked absolutely fine, but a good tug would sometimes see it fall apart.
    more pronounced on unsleeved straps but still happened on sleeved ones too.
    • Like Like x 2
  9. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,539
    5,621
    Near Mold North Wales
    :thumb:
    • Like Like x 1
  10. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Well done!:BigGrin:
  11. spannermanwigan
    spannermanwigan Read Only Funster
    May 22, 2008
    394
    207
    wigan, lancs
    good for you for sticking at it, glad everything turned out just fine.:Smile:
    Regards
    Steve:thumb:
