Telly Troubles
Discussion in 'Motorhome Chat' started by martin2603, Jan 31, 2014.
  1. martin2603
    martin2603 Funster
    Nov 25, 2013
    340
    290
    kent
    I have a Cello freesat tv coupled to an Oyster Autoscew Sat dish, Having trouble to get the thing to work, tv has been checked , Cello its ok, but must be connected to the sat dish, Dish supplied now says the system has a decoder that reverts the signal to analogue. thus using the conventional aerial input. Does anyone have any experience of this problem with Cello?
  2. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    354
    309
    Devizes
    Not familiar with your kit but would ask the following:
    Is the tv output from the sat decoder analogue or digital. Suspect it's analogue is the telly turner set accordingly and auto tuned.
    Has the decoder got a scart output, if so don't have to worry about signal type or tuning.
    Good luck
  3. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,912
    23,658
    Narrfoook
    Not familiar with the latest Cello, but very few tv's have a Sat tuner built in..
    First question.. Has it EVER worked ? Or is this a new set up ?
    More usual would be ( from the dish down )
    Sat dish
    Sat dish controller
    Sat tuner ( sky box or freesat ( NOT freeview )
    Television
    Is that how you have the set up ?
  4. gillnphil
    gillnphil Funster
    Apr 12, 2010
    973
    4,714
    West Suffolk
    cello tv
    Use the "quick start" button on the remote. this tunes it in in seconds. should fix the problem.
    Phil
  5. tinkerbell
    tinkerbell Funster
    Jan 30, 2014
    65
    13
    WORCESTERSHIRE
    Tv signal
    Hi,
    New to this so here goes, we have had this problem since about late October, no signal to watch tv with, can only get a sky channel and a couple more, looked into this further and found that it is because there is a new satellite up in the air - Astra 2e see this - http://www.n2yo.com/?s=39285 - apparently it is not going to be in proper operation until late Feb if were lucky. You will then have to get your sat dish re coded. These people are also helpful -mayennesatellite <mayennesatellite@aol.com> if you look at the www.n2yo.com you will see that it is over the Maiko Nat Park at the moment, you can find other info from here. Good luck, if you get it going let me know, But, no good getting it done until satellite is settled.:Wink:
  6. martin2603
    martin2603 Funster
    Nov 25, 2013
    340
    290
    kent
    Thanks for your thoughts, I tested the TV at home with the hdmi feed and the sat cable direct (sky) works fine. I think it is not getting the signal from the decoder, I sometimes get a channel listing but on selecting one nothing happens. I t was fitted by the supplying dealer, methinks I shall be paying them a visit, Luckily there is a good Brit Stop close by. Real Ale Pub !
  7. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,678
    5,879
    Guisborough
    You say you tested it at home with the sat cable direct, I take it you mean the co-ax cable straight from the dish so that says that the cello has a sat tuner in it so you just need the sat cable co-ax straight from the Oyster box (not tuner/decoder) into the sat socket on the TV.
    This is how our Oyster dish runs straight to the Avtex with sat tuner built in
    Martin
  8. knokinonabit
    knokinonabit Funster
    Dec 28, 2011
    2,483
    2,453
    Stokesley, North Yorks
    "Telly Troubles"
    Aren't they multi coloured, fatties with aerials on their heads ?
    :getmecoat:
  9. laneside
    laneside Funster
    Aug 14, 2009
    3,589
    5,625
    Oradour sur Vayres
    As always with these posts it can be difficult to grasp the original posters gist.
    We have the Cello travel master and yes it has a built in decoder
    i) connect co-ax cable straight from dish to to tele.
    ii) switch tele on (takes an age)
    iii) press scource button on remote select Satellite and press OK
    iv)Press quickstart on remote and be patient I have never known a slower tele. for searching
    Assuming your dish is set properly to one of the satellites then something should happen
  10. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,922
    12,112
    Taunton Somerset
    Can you post a photo of the back of the TV with the leads plugged in?
