Taps (1 Viewer)
Jan 31, 2016
1,901
3,377
Alness, Cromarty Firth
Hymer B544 (2012)
newbie
In my Hymer bathroom the connectors for the hot and cold pipes leak, I've had them fixed by local 'expert' once but they are leaking again.
I've removed them and I'm pretty sure after inspecting the taps that it's the red or blue connectors that are the problem, not sure if it's the tap end or the pipe end. No splits in pipes or taps.
Is there a better connector for this ? or should I just buy two new connectors ? the central pin is also worn so that also may be a problem.
Tia
Dec 12, 2010
5,409
21,557
Cumbria
since 2011
A pic might help and is the leak coming from where the hose clamps onto the red/blue spigots or is it where the red/blue bits fit into the tap body as that can be an "O" ring issue, assuming the tap body hasn't cracked or suffered frost damage.
BusyBuilder
Jan 31, 2016
1,901
3,377
Hymer B544 (2012)
newbie
TBH I can't really see, and no cracks to be seen and o'rings are okay, I'll order two new spigots and go from there I think.
