Taps/shower pulsing
Discussion in 'Tech/Mech General' started by Emmenay, Sep 19, 2012.
  1. Emmenay
    Emmenay Read Only Funster
    Dec 11, 2011
    364
    274
    Anywhere
    I am trying to educate myslf as to why the taps in the MH are pulsing, especially at low flow. What I think I have figured out is that the accumulator/expansion tank should eliminate this so is it time for a new one?
    I have a shurflo pump and a fiamma expansion tank.
    How long will the pressure last in the tank if it is not used for a while. As I understand it the tanks are shipped pre pressured so would they lose their pressure unless they're broken/faulty?:thumb:
  2. Steveboy
    Steveboy
    Oct 13, 2011
    90
    124
    Wherever my wheels stop.
    water pulsing
    Just had that on my Rapido. Pumped the expansion thingymajib up to 20psi and while I was at it tightened all the screws holding it together by half a turn and same for the jubilee clips on the attached hoses. Job a good one and shurflo pump no longer pulses and I have a decent shower again.
    hope this is helpful.
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,087
    17,755
    YO11 2BD
    Fiamma accumulators are pre-pressurised but can be 're-inflated' via the shreader valve on the body....best with a foot pump as the pressure builds up very rapidly.
    from memory it is either 9psi or 13psi...I'm sure the pressure is printed on the label on the body and almost sure it's 9psi.
    but...it could be the diaphragm which has split...you'll know when you inflate it.
    turn the pump off and open a tap.....if its the diaphragm, water will continue to come out the tap as you inflate until the pipe is empty, then air will come out.
  4. Emmenay
    Dec 11, 2011
    364
    274
    Anywhere
    Not sure if this has any bearing on it but, during normal use, when i turn a tap on the pump starts up instantly, or within 2/3 seconds, every time. If there was a store of pressure would i get longer before the pump kicks in?
    I will try your suggestion tomorrow pappajohn :thumb:
