tap and water pump problem
Discussion in 'Motorhome Chat' started by con-tiki, Jun 5, 2012.
  1. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    Leeds, West Yorkshire
    I need a replacement kitchen reich mixer tap on my hymer. Does anyone know the size of tap ie ? mm bore. I also have a question regarding my submersible water pump. It appears to have 2 pumps..one looks broken...are they supposed to supply different areas ????
    here are some pics
    Shirl
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,620
    22,808
    Narrfoook
    Looks to me as though the second one is actually the water level ?
  3. 1948
    1948 Read Only Funster
    Dec 3, 2009
    444
    46
    surrey
    refering to mixing tap , changed mine , Reich tap comes in 33mm diameter for my B584, think there is a 27mm bore also , To be sure , you can measure the bore from underneath tap once you remove the drawer. There is a step by step guide at the HYmer owner site. Hope it helps
  4. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,483
    2,595
    UK / Spain
    Hi, sorry cant help, but I do know that Hymers have a micro switch on the taps, maybe there is nothing wrong with your pump or the actual tap. :Doh:
    Someone will be along soon with the right answer.:Wink: Just hold fire a bit, before ripping everything out !!!!!! :Rofl1: Bob.
  5. gordoncbrown
    gordoncbrown Funster
    Oct 2, 2011
    834
    568
    Scotland
    Not sure on the bore as I don't have a Hymer. I would however double check by measuring anyway. They are available from St Johns Cross. Reich Kama.
    Hope this helps.:Smile:
  6. bobandjanie
    Apr 28, 2008
    4,483
    2,595
    UK / Spain
    Just had a look, and has a few tips for Hymer owners. :Smile: Bob.
    Here: http://www.hymerclub.co.uk/hcitips.htm#tapaccess
  7. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,363
    5,387
    East Sussex 01-580-881288
  8. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    The shower and bathroom sink tap seem to be ok....Removed the little hot/cold disc and can't see any screw to enable taking the top of the tap off..
    Shirl
  9. 1948
    Dec 3, 2009
    444
    46
    surrey
  10. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    well....managed to get the top of the tap off using brute force.....:Eeek: Don't know if I have broken it !!!! The wires were loose....
  11. 1948
    Dec 3, 2009
    444
    46
    surrey
    Messy, think it will be much simpler to just replace the unit for what it cost , the other ends of the wire is connected to blade fitting underneath, It will be just a simple job for unscrewing the 27mm/33mm screw from under disconnect the two wires lift unit , put new one on join up wire (supplied with new unit) screw up That is it, make sure order right size bore tap
  12. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    Got new tap.....How on earth do you undo the old one . It seems to disappear up into the hole .... The connections are not the same either....Oh and the cupboard is about just over a foot wide to try and get to the tap....:Eeek:
    Shirl
  13. Terry
    Terry Funster
    Dec 27, 2007
    10,759
    6,253
    South yorks
    you cannot see it in the photo but just behind the red pipe (pic no 3) the brass long nut will have a screwdriver slot (big SD needed) or a long reach socket will be easier if you have one.The brass nut hold the silly horseshoe washer that holds the tap in place. Simply remove and reconnect the new taps not forgetting to put the new one piece nut over the pipes first so that you can tighten the taps
    terry
  14. con-tiki
    con-tiki Funster
    Oct 18, 2009
    475
    189
    So chuffed I managed to change the tap....Had to be a contortionist to fit into the tiny cupboard...Thanks for all the help :Smile:
    Shirl
    • Like Like x 1
  15. flatpackchicken
    flatpackchicken Funster Life Member
    Jun 27, 2010
    927
    897
    BICESTER OXFORDSHIRE
    Well done Shirl nice one, Regards Garry Flatpackchicken
