Tambour doors rattling
Discussion in 'Motorhome Chat' started by honkytonkpiano, Jun 8, 2014.
  1. honkytonkpiano
    honkytonkpiano Read Only Funster
    Jun 6, 2014
    4
    Hampshire
    Has anyone solved a problem of rattling and vibration from a tambour door? The toilet door on my Autocruise Jazz makes a terrific racket on rough road surfaces, and until I solve that, I won't be able to identify the many other sources of noise and vibration! All ideas gratefully received.
    Thanks,
    Mike
  2. simply
    simply Read Only Funster
    Apr 24, 2014
    202
    193
    Devon
    Rattles
    Earplugs!?
    :Doh:
    • Like it Like it x 1
  3. Mousy
    Mousy Funster Life Member
    Sep 13, 2013
    2,267
    8,032
    Sa15 2DG
    Hello and welcome to fun. Friends of ours used polystyrene packing foam shapes as wedges, jammed top and bottom of door. Hope this helps.
  4. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,964
    3,939
    Corby, Northants
    I close mine when travelling and it's fine !
  5. The Wino
    The Wino Funster
    Mar 23, 2012
    1,324
    2,424
    leicester
    The posher version of our motorhome has a velcro strap to fasten the tambour door back when travelling (chausson welcome 510)
    David
  6. honkytonkpiano
    Jun 6, 2014
    4
    Hampshire
    Thanks, David. Would it be possible to post images showing where and how the vecro strap has secured the door, please?
    Best regards,
    Mike
  7. honkytonkpiano
    Jun 6, 2014
    4
    Hampshire
    Turning the radio up louder would also help but that's really intended as a solution for rattles in a company car...
  8. honkytonkpiano
    Jun 6, 2014
    4
    Hampshire
    I've also tried door wedges and even a rubber sink drainage mat. The latter made a little bit of a difference, but I am concerned that I migh eventually make the doors curve a bit. I just wish Autocruise had used an ordinary sliding door: this tambour door doesn't go round any corners, so it seems a bit overkill for a straight run.
  9. Mousy
    Sep 13, 2013
    2,267
    8,032
    Sa15 2DG
    I see what you mean. The one I've seen with wedges is curved. I've also noticed a van with the Velcro strap to hold it back. The strap was fixed to the hinge side of door and held the door shut.
    I'm wondering about a cheap sleeping camping bed roll thing, as the sink mat worked for you. You maybe could cut a long strip to cushion the door when shut?
    If you manage to come along to a meet, we could all have a look and scratch our heads with you!
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,937
    10,302
    i solved this issue on a previous van by fitting 2 elasticated straps, one 6inches down from the top, the other 6inches up from the bottom. i used a self tapping screw and a washer to hold to the inside edge of the door and a larger pan headed screw on the outside door frame. the tighter you can get it, the less it rattles. I would prefer to see a bifold door than a tambour one on the bathroom. they really arent ideal in a motorhome, but the designers rarely use their products.
    the other problem we had was on 2 occassions the door jumped out of its runners and jammed half open. its a right pain to put right when you can only reach one side of the door
