B
badger1441
Hi all,having gone to the trouble of converting my '87 talbot express 2.5 diesel to turbo spec [good turbo,injector pump,lowered cr to 20:1,upped injector pressures,completely new 2 1/2" exhaust system, i have a problem-it wont rev up above around 2000rpm . It idles beautifully,but feels like a petrol engine with a weak mixture. I have good compression,no problems with low fuel pressure to pump [ i fitted an electric in-line pump,to make sure],took great care with cam& pump timing [it wouldnt run as well as it does if they were out+ smoke from exhaust seems normal], no obvious blockages to air induction/turbo/exhaust, injection pump is fully bled, i cracked injection pipes off one by one whilst idling,and engine speed decreases equaly between cylinders.I set the injection timing roughly whilst building,and advanced till it knocked,then backed off a tad till it quitened.....Please HEEELLLPPP!!!!:shout: Keith,dorset.
