T.V ? (2 Viewers)
crabman
336
188
Anglesey Wales
just looking
newbie
i have a 12 v T.V it not will run on the leisure battery, when I plug in to the mains it works perfect, if I unplug it from the mains the leisure battery will not run the T.V can any tell me why ?
thanks In advance
crabs
Jul 29, 2013
9,071
18,508
Salisbury
Hymer B678DL A class
since 2011
If you are on hook up it should work on your batteries sounds like a fuse blown somewhere?
Clickem
1,034
1,073
Northumberland
None
7 years
The probe on the 12v power cable that pushes into the female connector contains a fuse that has blown on ours a couple of times
ambulancekidd
Sep 23, 2014
10,365
28,388
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
Are you sure that your leisure battery is ok? Me thinks its time it was tested. The battery may well operate your lights etc but the TV draws a much larger current. Oh do not trust the vans own battery gauge, they're notoriously optimistic & therefor unreliable.
teensvan99
231
250
Margate
coachbuilt
As stated check the leisure battery voltage. If less than about 12.2 volts the TV will not switch on.
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
read all your replies, I have tried it from the cab golly no luck, the fuse is ok clickem, it may be a good idea I get the battery checked as ambulanceman says, it is about the only thing left I have not checked, might be a fuse ii have overlooked speve I will check the lot again as well, just picked up your post teenvan99 it sounds it may well be the problem, the power coming put the battery I will get it checked out
anyway thanks again if ii can find the problem I will post about it
buckby
213
147
nottinghamshire
coachbuilt
Did the 12 volt cable come with the television if not it could be wired up the wrong way round just a thought
May 8, 2016
1,685
80,805
silver coast, portugal
C Class: Low profile
Boatie for 20 years
Presumably you have a 12v power "brick" and a separate mains power "brick" to operate the TV??
Do you have a 12v socket in the can running off the engine battery? If so, worth trying that with the TV before anything else.
If that works, it's probably a missed fuse or a knackered leisure battery.
Probably best to plug in the 12v power brick into the socket you usually use and check if you have an output voltage before chucking out your leisure battery (or having it tested by someone trying to flog you another). Then work backwards, if no power, check the plug fuse, then try something else in the socket that it plugs into (cigarette lighter?) and if that doesn't work, finally, check the 12v fuse for the whole 12v circuit.
crabman
crabman
336
188
Anglesey Wales
just looking
newbie
have a car eclectics guy coming to check the system and the battery this week, he has fixed sparks on MH before and has the test equipment for the battery, so we will see, thanks again for your time to reply everybody
43,323
49,428
Crabman states it works on mains voltage.
If the 12v lead was wired in reverse it would blow the tv completely....no 12v, no 230v.
May 8, 2016
1,685
80,805
Boatie for 20 years
Either a diode to protect against reverse polarity or a blown fuse. These things usually use unfused switched mode power supplies to provide a 12v DC input. If the 230V power supply works, then the set is OK, so it is most likely a 12v supply problem as described r a broken 12v supply brick
Fault finding in this matter is known as the half-split (or divide and conquer) methodology
"The technician will use their experience to make an educated guess as to where the fault may lie, and then progress forward or backward in the particular circuit whether it be"
Broken Link Removed
DanielFord
3,020
3,086
I'm going to take a wild guess here. You know when you get the 12v socket attachment out of the packet, and there is the spare positive head, and we all think "why would I need that?" well it has a different pin size. So I'm guessing you need to swap the heads so that the pin hits the positive connection.
43,323
49,428
Jan 23, 2016
1,887
305,132
Wales
Adria Coral 660SP
25 years
Next time you're parked up near someone else in a MH, introduce yourself, explain your TV problem and ask if you can try it in their van.
Results will determine if it is the TV and/or TV power cable, or with your MH electrics.
JJ
Mágica
May 1, 2008
19,258
48,031
Burstner Privilege T
over 50 years
A multimeter is an essential part of my motorhoming toolkit.
You can check your battery voltage.
You can check your 12 volt tv power lead.
You can check all your fuses.
I got mine from Maplins for about seven shillings and sixpence...
JJ :cool:
