T V Mounting
Discussion in 'TV & Satellite' started by vectian, Mar 6, 2015.
  1. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    bracket.jpg Just purchased this for M H as I've acquired a new TV. Unfortunately using the same mounting block on the wall as the old one used makes the TV too high to fit under the side locker by an inch. Now all you technical engineering types would undoing the central pivot and moving the arm to the underside cause any undue or extra stress to the unit.
    Thanks for all the sensible comments I know I am going to get.
  2. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,371
    1,456
    Suffolk
    Is it possible to mount the whole thing upside-down ?????
    • Like it Like it x 1
  3. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,179
    3,014
    Kendal, Cumbria
    No it will not affect the strength of the unit at all.
  4. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    thanks sundowner and tonyidle.
    It cant be mounted upside down as the 4 pronged bit that attaches to the tv set has a hook and eye type attachment to hold it in place and a grub screw to secure it
  5. Manic
    Manic Funster
    Nov 4, 2011
    1,049
    1,180
    Uk
    Is the middle pivot a nut and bolt, if so could you put top arm underneath , that would lower it a bit.
  6. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    Well the deed has been done and all seems to be ok and tv now fits under side locker
  7. Sundowners
    Oct 30, 2007
    2,371
    1,456
    Suffolk
    BUT HOW?????????;):)
  8. vectian
    vectian Funster
    Sep 21, 2013
    152
    132
    Isle of Wight
    The way I asked about. Undid the central pivot and put the front arm underneath the back arm instead of it being on top. Seems to be working ok
Similar Threads
  1. Baycott
    5
    244
