T rubber profile supplier & water ingress ?
Discussion in 'The Beginner' started by EA7VPG, Jan 24, 2012.
  1. EA7VPG
    EA7VPG
    Jul 27, 2011
    47
    28
    Malaga, Spain
    Hi...
    Well my bargain Elnagh Sleek isn't turning out to be the great bargain. Where the cab attaches to the main body two vertical alluminium strips have rivetted to the body on both sides. Never thought much of it until I removed a small kitchen utility holder beside the sink. The panelling was absolutely soaking behind it. After ripping the inside out of the cabinet above the sink you could see where the water ingress was coming from, the curve where the cab interface joins the box above the cab. In summary what has been happening the water has been coming in for years, soaked and rotted the interface about two centimeter along the full edge of the interface top to bottom. The alluminium strips where to make the edge more rigid to help seal along the rubber profile edge. The access road to our abode is quite bumpy which has flexed the interface revealing a crack right along the interface. What I intend to do is take the alluminium strips off and use the rivet holes to fill the rotten void (dried first) with expanding foam or similar then fit a new T rubber profile along the full length and seal with Silkaflex 291 glue/sealant.
    My questions are... what is the best solution to fill the void along the edge, is Sillkaflex 291 the best option for seaqling the new rubber profile to the interface and finally where can I buy the T profile from. The profile needs to be 5cm wide with ideally a 'D' shape on the top as you look at the edge. Is silicon better ? any thoughts appreciated,
    atb Neil
  2. vwalan
    vwalan Funster
    Sep 23, 2008
    7,630
    3,926
    roche cornwall
    hi .you have woolies trim up near peterborough/corby way .or a place called seals direct .both can be found on google i think.
    becarefull with silicon it tends to not contract and expand as good as sikaflex . there are others bostik do one cant remember the name now got it from my son once worked really well. sometimes if there is a boatbuilder near you they have good stuff as well. unfortunately its a shame the manufacturers do such a poor job on these things . you arent alone .
    hope you get it fixed . woolies are a good old fashioned really helpfull crowd . reccomend them first usually. but the other crowd get good mentions as well.
  3. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
  4. bobandjanie
    bobandjanie Funster Life Member
    Apr 28, 2008
    4,503
    2,610
    UK / Spain
    Seals Direct give a great service. I wanted to try a few different ones that I had seen on the website. Rang on a Monday morning, Tuesday morning I had the samples and a catalogue, tried the samples out. Phoned Seals Direct again (still Tuesday)and on Wednesday morning I had the correct one, the length I needed, delivered to me. Perfect service. Jane :Smile:
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,120
    17,789
    YO11 2BD
    chances are there used to be some wood batton framework in there...probably rotted to nothing.
  6. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,396
    5,427
    East Sussex 01-580-881288
    Hi EA7vpg
    My advise would be to always replace rotten timber with good timber as that is the main strength of your motorhome, sikaflex or silicone will offer no rigidity at all and you will only end up with more problems.:cry::cry:
    Kind regards
    Glenn
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,771
    6,291
    South yorks
    That is 2 ins wide far too big a gap to sikaflex or T rubber --If you mean 5 mm (1/4 ins) then go for both IE stick T rubber in place with Sikaflex :thumb: You may find a local Double glazing co has T rubber :Wink:
    terry
  8. EA7VPG
    EA7VPG
    Jul 27, 2011
    47
    28
    Malaga, Spain
    T section profile supplier
    Thanks to all who came back with some valued information.
    I looked at all the suggested sites with no success as the width of the T section wasn't great enough. http://www.deltarubber.co.uk/rubber_extrusions.htm had the item I required but only did 30m lengths. They put me on to http://www.coh-baines.co.uk/ who actually supply deltarubber. Very helpful with 5m in the post tomorrow... catalogue page 78 item: IRS111EP .
    Looking further at the problem the T section fitted by Elnagh was not wide enough as the gap between the cab and the main unit was far to great regardless of how much Sikaflex you squeezed in. The new T section should overlap quite nicely being 38mm wide. Unfortunately I cannot squeeze any timber into the gap where approx. 30mm has rotted along the full edge. I am proposing to duct tape along the full edge with filler holes every 15cm and try that expanding foam you use when installing windows. Any thoughts or observations on this one most welcome.
    atb
