Switching off water pump when not needed (1 Viewer)
Jan 26, 2010
577
1,493
Conwy, North Wales
Relay self build
Had a problem whilst in Germany recently which may be of interest to others. We were having lunch in the van when there was a sudden and loud gush followed by water dripping from the sink area.
Luckily, we were sat there and were able to switch the water pump off quickly. I could see through a gap in the kitchen sink cabinet that the hot water feed had come away from the base of the tap so had to partially remove the sink unit to get at the hose clip to refit it.
I dread to think what we could have faced if we were not in the van at the time as we had three quarters of a tank of fresh water on board so now we try to turn the pump off whenever we are not using it.
The van is an Autocruise Alto panel van conversion and I guess that the water system is pressurised when the pump is on which must put some load onto any joints in the pipework?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That's right. Just like at home, with normal taps.
Ours, like many others, has a switch in the tap and that switches the pump on "on demand". Now you posted this, this looks a safer system but a bit more to go wrong in the tap.
icantremember
8,328
17,539
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I haven't had a problem like yours yet, but being aware of the possibility of it happening and returning to find the tank emptied into the m/h I do, when I remember, turn the pump off when going away from the van.
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
Mine is also a pressurised system with an anti surge chamber. I also switch the pump off when we are away from the van or if its not being used. My old Tiffin had the same system and I finished up with a locker full of water when a joint blew whilst at a meet in Oswestry a couple of years ago.
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
I switch the pump off when not in the van and also when sleeping (aka stupor). :thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
You being a serious dabbler in sparks should have an automatic switch so that when you lock the van from outside it trips the pump. Fail-safe.
I'd link ours to the alarm but for the fact that it's not needed.
Rapide561
471
167
Leeds and Lake Garda
Pump
Same again, always turn it off. Had a similar experience years ago with a loose pipe although only a small amount of water escaped.
Russell
Oct 3, 2012
170
125
Hastings
Since Oct 2012
If really worried about it, turn pump off then open a tap to relieve pressure from pipework.
Jul 28, 2010
1,710
617
The world
Small car
Common problem. Yes always turn pump off when not in use
My Rv has a switch in the kitchen. And another in the shower room
So you can turn pump on / off as required
The yanks think of every thing :thumb:
Jul 17, 2012
669
368
Bury St Edmunds
1 year on and loving it!
:Eeek: I've never even given switching off my pump a thought!
Mine are microswitch taps, so the pump won't come on if a pipe goes - as to wether or not it will dump all the water from the tanks into the mh - don't have a clue! :Sad:
Snowbird
11,818
22,345
Liverpool.
Fifth wheel.
Since 11-05-2000
If you have micro switches I dont think you have anything to worry about. Its only the pressurised systems that would pump all the water out in the event of a burst.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Always turn ours off when away from the van, but not usually at night in case someone needs to go!
Allan
Jul 17, 2012
669
368
Bury St Edmunds
Phew! Thanks (but that's what I suspected! ::bigsmile: )
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
I always turn ours off when we go out and at night. There are various switches both inside and out, one being by the toilet, to turn it back on if required. If full, 85gals would make a teeny tiny bit of a mess. :ROFLMAO:
Feb 9, 2008
8,943
18,691
Corby, Northants
Coach Built
Yup! me too, When we were overwintering in Spain the boiler kept dumping the water during the night and then the sodding pump would kick in and would have run until the cold water tank had emptied. Now we always switch it off before we go to bed or leave the van.
No longer a problem when the boiler takes a dump!
Melchior
129
82
Amstelveen, Netherlands
Alcove
Since August 2012
Got the habit from my dad when I was little and we had caravans. Always turn it off at night, when driving and when out.
Someone mentioned anti-surge, what's that?
Destination Unknown
398
835
Anywhere and everywhere
American A Class
Not Long Enough...!!
Like Melchior we are caravanners at heart and turn everything off everytime - saving battery.::bigsmile: Even now in our RV and on electric we still turn lights off straight away and turn the water pump off after use.
Friends of ours accidently left a tap in the bathroom running with the plug in the sink and because the water pump was always left switched on it flooded the RV.
We even turn the gas off when travelling too.
Regards Brian and Chris
