Switch positions
Discussion in 'The Beginner' started by Tony Ryan, Jun 5, 2016.
  1. Tony Ryan
    Tony Ryan
    Jun 5, 2016
    4
    Sussex
    hi all could someone please explain what position to put the three way switch in aux middle vehicle when hooked up to mains .when your driving and when you're parked thanks in anticipation
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,705
    17,323
    YO11 2BD
    Mid position is usually off....not charging or using either battery and just running everything off the charger/power supply.
    Set in mid then turn on some lights.
    Press one end of switch and closely watch the lights....do light become slightly brighter ?
    If so that is the hab battery charge position.
    Even easier if you have a volt meter across the hab battery.
    If off grid you need to know which is which or you could flatten the starter battery by mistake.
  3. MH 55 FUN
    MH 55 FUN Funster
    Feb 18, 2016
    2,049
    3,102
    Rural South West Wales.
    On ours, and some other MH's . . AUX is selected for the leisure battery / EHU to supply power, VEH is selected for the engine starter battery to supply power ( sparingly, if ever ) & the middle position is off - no supply from either the leisure battery or EHU or the engine starter battery.
    This example, no doubt , doesn't apply to all MH's.
  4. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    Another bit of advice is that the switch does switch the full current they usually only switch a small current that switches one of two relays. Now relays don't use much power but they can still flatten a battery if left on for a couple of months. Therefore get in the habit of leaving it in the off position when the MH is left unused. A multi-meter is good value and when used regularly you will soon get to know when either of the batteries require recharging.
  5. Tony Ryan
    Tony Ryan
    Jun 5, 2016
    4
    Sussex
    Thanks for your replies but I still don't know what position it should be in when hooked up to mains and whilst driving
  6. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,365
    9,811
    whilst driving on leisure battery and on mains, one day in 4 on cab battery, the other 3 on leisure. when parked up and not in use and not on hook up, then in centre position
  7. pappajohn
    Aug 26, 2007
    29,705
    17,323
    YO11 2BD
    When driving the switch position is irrelevant, it will be charged by the alternator regardless.
    On hook up you need to identify which battery you want charging...hab or cab....and set the switch to that battery.....you really need a volt meter to check properly.
    On hook up and switch center neither battery is charged or used....Only the charger will supply your 12v circuits.
    See my previous post.
  8. Tony Ryan
    Tony Ryan
    Jun 5, 2016
    4
    Sussex
    Thanks guys it makes sense to me now
  9. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,185
    14,958
    Leeds the one up North
    Always helps people to help you if you supply pictures. This is so easy to do direct from your smart phone on this forum.
    Just select upload a file and the option from camera while using it as the browser.
    Also the make of control panel and vehicle etc
  10. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,329
    34,803
    We had such a switch in our Autoquest 100. The following text is taken from the Elddis manual.
    We inadvertently switched over to Veh one night when we hadn't had the van long and needed to get a jump start the next morning as a result :)
  11. Tony Ryan
    Tony Ryan
    Jun 5, 2016
    4
    Sussex
    Thanks for that very helpful
Similar Threads
  1. Timireson
    20
    1,016
