Swift Royale Water Pump Switch (1 Viewer)
Baker69
85
Worcestershire
6 Months
Hi all,
If anyone out there has one of the older Swifts with the Panel Systems Ltd's control panel, the rocker switch for the water pump is a 3 position switch, the central position is for off, if you push to the right it turns the pump on, but what is the 3rd position i.e. the push to the left position? :Confused:
43,295
49,274
it could be for an external pump socket....to pump fill your fresh water tank from a container.
or it could do nowt.:RollEyes:
if you can remove the panel just have a look at the wiring on the switch.:thumb:
B
Baker69
85
Worcestershire
6 Months
I'll have to have a look to see if it is wired up, I'm pretty sure I'll find it isn't.
Yes, our Caravan used to have an external socket in order to fill the toilet flush with fresh water, it was really useful. There isn't one on the Swift, however when you open the Water Filler Cap there is a circular blanking plate or something immediately above the filler hole and I can imagine such a socket being fitted there on some MH's?
43,295
49,274
Our Caravan had the same type then.
I have a spare CarverThames pump somewhere so I could make one.
worth doing in my opinion.
when you get back with the water it aint easy getting it in unless you use a watering can....over and over again.
i made the mistake of using the wrong size container and the pump wouldnt fit in the container.....having no watering can i had to remove the dinnete seat and pour it in to the tank through the large inspection cover inside the van...never again...sooner go thirsty:Doh:
B
Baker69
85
Worcestershire
6 Months
I agree, initially we tried filling the tank directly from a Jerry can, very messy and only about half the water went in the tank, half on the floor! At the moment we fill the tank directly from a hose connected to a tap.
I think it's a little project to consider when we've got back off our next adventure. :Smile:
