Swift Mondial Mv Water Pump
Discussion in 'Tech/Mech General' started by philip-g, Jun 17, 2015.
  1. philip-g
    philip-g Read Only Funster
    Jun 17, 2015
    Bradford
    The water pump on my 2001 Swift Mondial MV has stopped working - probably from lack of use and I can't locate it - can anyone help please and also advise the prospects for a repair if necessary. Any advice gratefully received philip -g
  2. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,604
    12,015
    E Yorks
    Not sure what layout you have but we had an Autocruise Accent (same as Swift Mondial in all but name and some finishes), it had a front half dinette and rear lounge/bed, the pump was located under the nearside rear lounge seat/bed base tucked up into the corner.
  3. philip-g
    Jun 17, 2015
    Bradford
    Many thanks Mel but mine is the model that has a forward facing double seat and the bathroom / wardrobe at the back. The diagram in the handbook isn't much help as it doesn't show the pump's location but it does show it as being separate from the water tank. Can't see anything inside the cupboards that could be housing the pump so I'm a bit stumped - but thanks for taking the trouble to respond. philip-g
  4. bonniechris
    bonniechris Funster
    Oct 5, 2014
    77
    27
    somerset
    We have a swift differentmodel but water pump in middle of walkway in hatch in floor under carpet easy to getto just lift carpet and small lift out panel hpe this may help
  5. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,779
    7,718
    Plymouth
    Pressure pump or micro switch type?
    Have a look in your f/water tank may be a submersible if not follow the pipe look for a fuse (y)
