swift kontiki rear lights
Discussion in 'Tech/Mech General' started by lesleyjean, Mar 7, 2009.
  1. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    Hope someone can help.
    Rear lights drivers side do not work.
    Brake light works, indicators work, reversing lights work, hazard lights work but the 2 smaller bulbs which operate just the lights do not work.
    Is it a fuse? Help
    Changed bulbs, problem not with bulbs.
    Lesley
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    hi Lesley,
    the fuse box is in the glovebox......a flap on the box floor.
    not sure if the rear lights are fused left and right but worth checking. is it just the rear ?. i would think the front and rear are on the same fuse.
    it could be the bulb holder has a bit of corrosion on the contacts. CAREFULLY scrape it off with a small screwdriver and a spray with WD40. make sure the lights are turned off or you will blow the fuse.
  3. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    I will give it a try, let you know shortly.
    Lesley
  4. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    Not working yet
    I will have to buy one of those multi power thingies and see if there is any power there.
    Thanks John and thanks Roger
  5. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Hi Lesley,if you have put a new bulb in and still not lit then it will be either fuse, bad earth, or bad connection somewhere :Wink:
    terry
  6. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    More help needed
    Not fuses, Not bulbs, Not connection, bought a multimeter no power.
    What do I do now?
  7. Terry
    Terry Funster
    Dec 27, 2007
    10,808
    6,321
    South yorks
    Trace the wiring back :cry: to find a break :Sad: or go around to see Roger and let him play :Rofl1::thumb:
    terry
  8. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,426
    5,457
    East Sussex 01-580-881288
    Should have saved your money and licked your finger and stuck it in the bulb holder:Rofl1::Rofl1:
    Seriously, easy way is to just run a live feed from the live lot to the dead lot behind the rear skirt or find the break if you can.
    Peter
  9. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    Thank you Terry and Peter
    Roger do you wanna play?
    Hee hee
    Lesley
  10. lady jann
    lady jann Read Only Funster
    Apr 18, 2008
    653
    welsh border
    hiya lesley !:Blush:
    see you causing trouble again !!:BigGrin:
  11. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    Hiya Ray
    Yeah, just love it.
    Do you wanna play Ray, hee hee. (with my lights)
    Lesley
  12. hilldweller
    Dec 5, 2008
    27,885
    26,959
    Macclesfield
    Is this Ducato based ?
    We have fuses all over the place - under screwed panels on LHS and RHS. Everything seems to have at least one fuse.
  13. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    Hi Brian
    Yeah Ducato based.
    Swift Kontiki L I think 640 2002 version.
    Lovely motorhome methinks.
    Got any more ideas.
    Lesley
  14. hilldweller
    Dec 5, 2008
    27,885
    26,959
    Macclesfield
    Yes....
    From the Fiat 2000JTD manual:
    The side light circuit is protected by special fuses located in the engine bay junction unit and in the under-facia junction unit.
    Short-circuit junction D097A distributes power to front lights F010 and F011 and tail-lights F030 and F031 and number plate lights F050 and F051, via pins 2, 3, 5, and 6. This line is protected by fuses F12 and F13, located in under-facia control unit B002.
    Cherchez F12 F13. B2002 is show as having 4 fuses in it.
  15. tintinold
    tintinold Read Only Funster
    Mar 5, 2009
    33
    Northamptonshire
    Sound's like it could be a broken live feed wire, or a corroded feed terminal on the back light assembly, have not long bought a kon-tiki 640 myself, so still a newbie, also a new member,
    but working in the motor industry for 34 years, and still learning!
  16. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    its time to start crawling lesley :Rofl1:
    underneath the rear body, fixed to both left and right of the main chassis, you will find......joint box's :thumb:
    i found these after cutting the wiring loom to fit my t/bar electrics:Blush::Doh:
    these have waterproof covers but might have been disturbed in the past and not refitted correctly.
    prise the cover off with a screwdriver and check for power in the box.
    for reasons only known to swift there are a further two near the front, near to the cab/alko chassis joint....worth checking these two also.
  17. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    I would like to thank eveyone for your fast responses.
    I have just noticed that it is not only the drivers side rear light, but also drivers side rear top light and also drivers side of the rear number plate light, also the drivers side front top light.
    Can any of this be caused by damage repair to the front passenger side lights and bumper and panel above the bumper. As I only noticed the light not working when it came out of the body shop that repaired the front damage. I had to take it back to body shop because the front side light was not working.
    Is there any connection.
    Lesley
  18. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    hi lesley,
    all linked together on one wire....
    i still suspect the joint box on the chassis rail. :Eek!:
  19. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,190
    2,011
    Devon
    I will have to start crawling then John.
    John do you think the repair to the front has anything at all to do with it.
    Cause I can take it back to the body shop and ask them to fix it.
    I did get under the vehicle today, but too cold to stay and look properly.
    It is driving me mad.
    I am usually pretty good at most things but not electrics.
    Lesley
  20. pappajohn
    Aug 26, 2007
    30,364
    18,054
    YO11 2BD
    it possible but doubtful.
    the front will be on the same fuse but probably not the same wire.
    too dark to see now but it may be the wiring goes to the front first then to the rear but its very unlikely.....if it does then there will be two wires, one in and one out, at the front sidelight bulb holder center.
