Swift Bolero battery charging (1 Viewer)
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Anybody with a Bolero know if both batteries get charged together when on EHU, or do you have to select each one as you want it, I thought mine used to charge both together, but does not now, ??
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
You don't give exact details of your van but if it is like my Swift the chassis battery will only charge on EHU if that battery is selected on the control panel. I swap once a week to ensure that the battery is kept topped up (my van is on permanent hook-up at home).
Hope this helps
Bill
pablomc
772
237
Durham
Since 2009
As Bill says a bit more info needed on your panel and system. On my previous Swift it charged the Leisure battery first they swapped automatically to the engine battery, although it could be overridden.
172
67
Lincolnshire
low profile
On ehu my Bolero defaults to the domestic battery when charging. To charge the engine battery, that has to be done manually at the control panel. The van is 3 years old.
injebreck99
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Many thanks for the replies, my van is a 600 EK Compact, 2009 model, I just thought that it amused to charge both batteries together as normal, I must have been mistaken, senior moment. !!
pablomc
772
237
Durham
Since 2009
If it is the EC400 control unit then it should charge both.
Broken Link Removed
3.3 Smart Charging
On EC465 and EC460 PSU’s, the system
incorporates a smart charge feature, which
monitors both leisure and vehicle batteries
and automatically adjusts and directs the
charger power (and solar power if a solar
panel is installed) to maintain the leisure
and vehicle batteries at an optimal level.
