Swapping 12n and 12s sockets on towbar?
Discussion in 'Motorhome Accessories' started by YukonJac, Nov 22, 2015.
  1. YukonJac
    YukonJac Funster
    May 1, 2015
    165
    325
    St Remy de Provence
    Hi all,
    I just bought a Thule Easybase for the towbar on my Murvi and once it is on the towball, it obstructs the 12n socket so I can't plug it in. The 12s socket is just below - - does anyone know if it is it straight forward to swap the two sockets on the towbar without frying myself ? I'm handy with a wrench but know little about electrics....
    Photo of identical setup below - ignore the masculine had with the 13pin!
    Jacquie
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    Real easy as long as you make notes of the various wires and related pins.
    You could simply swap the whole bracket to the other side but the covers would open downward rather the up....not that it really matters as they arent fully waterproof anyway.
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    28,977
    25,675
    The cables to each socket go through the bracket so you need to disconnect the wires from each in order to change them around..
    The 12s socket has a live feed on pin 4 , so you need to find the fuse and pull it.. or disconnect the battery before starting .. otherwise you may blow the fuse..
    a useful drawing showing the colours and pin numbers, or do as John suggests.. just make a note of them
    [​IMG]
  4. mjltigger
    mjltigger Funster
    Nov 12, 2014
    1,574
    2,573
    Trowbridge
    It may be possible to do it without unwiring. Have a look on the back plate and there might even by cut outs that let you unscrew the front plate and swap the sockets. That's how they were on my landrover.
  5. YukonJac
    YukonJac Funster
    May 1, 2015
    165
    325
    St Remy de Provence
    Thanks very much - I think I can manage any of those solutions, but I vote for the easiest. Love the schematic!!
    I'll let you know how I get on tomorrow -
    Jac
  6. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,284
    3,730
    walthamstow east london
    if theres some slack on the cables its often easier to cut them close to the connectors so you leave a little of the colour on then swap them one at a time once its in the new position
  7. Gellyneck
    Gellyneck Funster Life Member
    Jun 5, 2014
    1,789
    2,217
    Scotland
    Could Jacquie not do that and then undo the two bolts in each socket, rotate the sockets through 180 degs (assuming the cable is flexible enough) and re-bolt them back onto the backplate? The sockets would then be correctly aligned again on the other side.
  8. YukonJac
    YukonJac Funster
    May 1, 2015
    165
    325
    St Remy de Provence
    The cabling seems pretty tight (which possibly precludes just swapping the whole assembly to the other side), but I haven't had a really good play with it yet - just got the rack tonight frozen fingers and not enough light here at CC Brighton!
  9. matamoros
    matamoros Funster
    May 15, 2008
    2,582
    4,123
    Rochdale, Tavira, S. Brittany & Europe
  10. YukonJac
    YukonJac Funster
    May 1, 2015
    165
    325
    St Remy de Provence
    Mission accomplished!! It was a doddle thanks to your encouragement - I swapped them over and rewired them both - all works great now. You saved me a few quid!! Thanks again lads -
    Jac:love:
  11. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    Unfortunately not that simple.
    The three fixing holes in the backplate are set in a triangle with one hole at the top....or bottom, cant remember.
    To turn the socket 180° would result in one fixing hole being at the bottom of the plate but the hole in the socket being at the top.
    But.....the plate could be turned 180° in both directions...left to right and top to bottom which would place all holes in the correct location.
    IGNORE THIS DRIVEL i see what you mean....simply flip horizontally from left to right.
  12. Gellyneck
    Jun 5, 2014
    1,789
    2,217
    Scotland
    Well, at least I understood your "drivel" so we must be as daft as each other!;):)
