Sundance530LP Bed Broken again (1 Viewer)
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Having (so I thought) strengthened the bed frames by adding a thicker bit of wood and metal brackets the damn thing broke again on Friday Night one side (luckily I had the G-clamps from before!) and then again on the other side on Saturday.
Any ideas what I can do next? I am thinking of adding a support on the front edge both sides, but the issue appears to be thickness of the top piece of wood which houses the slats.
43,319
49,395
same problem on our kontiki.
on ours its the front rail on the slide out bed base in the 'U' shaped lounge
fixed ours with cable tie-wraps but it doesnt look pretty.
other options would be...
1) strip out and rebuilt the bed frame using new wood and better joints...thats my plan eventually.:RollEyes:
2) tell Mrs colpot she'll have to wait 'til you get home for horizontal jogging.:Blush:
ourcampersbeentrashed
7,574
4,348
East London
well over 5 years
You are just going to have to stop jumping of the top of the wardrobe and swinging from the chandelier !!!!!
::bigsmile: :thumb: :Smile:
So sorry to hear about your bed problems but you better get it fixed quick you dont want it ending in divorce :Blush:
Have a look on ebay may be something there to help you xxxxxxxxxx
Good luck xxxxxx
DESCO
2,646
266
London
low profile
18 years +12 years tugging
I would have thought that you would have guessed by now Swift don't make beds to be slept on, they are only for show. You are expecting too much for your money.:winky:
Dave:thumb::thumb:
Mr Colpot
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Dave:thumb::thumb:
So - thats where I've gone wrong - expecting to sleep on the bed!:Smile:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
:ROFLMAO::ROFLMAO: Any pics for a suggestion on how to fix permanently ?
terry (joiner by trade)
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
Most of us would have no hesitation in beefing up the structure ourselves, if you are unable to do so for any reason and find yourself in Devon do give me a shout I'd be glad to help out. I have full workshop facilites and overnight parking .
ingram
87
Going slightly off topic here but, Terry, what is the difference between a 'joiner' and a 'carpenter'?
Thanks,
Harvey
DESCO
2,646
266
London
low profile
Thanks,
Harvey
One begins with C and the outher J obviuos en it :Eeek:
Dave:thumb:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Not 100 % sure myself :ROFLMAO: but joiners do anything :ROFLMAO: From all joinery work in houses(ground up to roof) shop fitting and shuttering-- and carpenters make furniture
If anybody knows more than that feel free to educate us :ROFLMAO::ROFLMAO:
terry
Link Removed
it seams I am both !!
haganap
12,758
26,438
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Thanks,
Harvey
One was an anorexic young lady whom produced some of the greatest music ever,
the other was the father of Jesus christ,:ROFLMAO::ROFLMAO::ROFLMAO:
sorry people couldn't resist it.
As for fixing the bed? sounds like better quality of wood or perhaps even a better design. I personally would be off to Devon in a shot :thumb:
Mr Colpot
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Roger
Thanks for the kind offer, as I said, I thought I had beefed up the bed. I think I can see where the problem is and I will be fitting an extra support in the middle of each side to see if that works. If it doesnt I may take you up on your kind offer. :thumb:
Mr Colpot
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
I took some pics, but feel the need to add arrows and descriptions, but cant now insert them into thread. Anyway, I am going to try adding an extra support in the middle and see if that works!hardhat
Mr Colpot
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Update: Have added extra support in the middle of each side and added L shaped brackets to each corner. Tested at the weekend and seems better, although the previous work appeared to work for a while, so time will tell.
DESCO
2,646
266
London
low profile
Hope you can now get a good nights sleep at last, after all that work you deserve it:winky:
Dave:thumb::thumb:
S
sinbad1
Best bet is your local chippy::bigsmile:::bigsmile:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi could you not have put the brackets in from behind -out of sight ?
terry
scotjimland
2,303
9,966
A Woosh bang
I guess you followed your signature advice .... :Doh:
:ROFLMAO:
43,319
49,395
thats the same seat base as mine and exactly the place mine failed....
Link Removed
but i have a second problem.....there's an access door to the underseat area/ outdoor locker so i cant fit a third leg:cry:
S
sinbad1
John
can't you just fit a hinged steel box section leg in the middle that tuc's away under the cross member when not required leaving you access to the inner door?
regards
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
leave your batman suit at home and stop jumping of the top of the wardrobe and you'll be fine, hee hee
Mr Colpot
Apr 29, 2009
1,203
740
West Sussex
Burstner Nexxo T740
since 2008
Link Removed
Not sure if the middle support isnt a bit of overkill. The brackets would probably do the trick. The problem is caused by the thinner top piece bowing under the weight, but the bottom piece remains straight and thus puts pressure on the end fixings. I have seen that on the Autocruise with similar layout the wood is thicker, but on the Ace Capri they have a third leg. Anyway, time will tell if it is fixed (off to France in a bit for a couple of weeks, so will know then) ::bigsmile:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
:ROFLMAO::ROFLMAO: I believe you :thumb:
terry
