sundance 590rl (1 Viewer)
suggs123
4
romford
swift sundance
hi can any one help me ive had everything working on gas ie water heater fridge but when I tried the ehu nothing worked no power what so ever but the ehu used to work by the way it the 04 decato
S
suggs123
4
romford
swift sundance
I think its the fuse but cant seem to find it
big map
4,597
182,269
Poole
Since 2009
Hi Suggs
As already stated first check should be to check the RCD trip in the van and also on the 240v supply.
S
suggs123
4
romford
swift sundance
yeah checked bothof them all fine only the fuse to check but don't no where it is
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Sorry can't help in the location but ehu from input into the van first stop usually the trip switch has it tripped ? If feed is OK to it ,try test trip button if that don't work the is no juice to van ,but you have tried that have you not ? :)
RowleyBirkinQC
2,347
226,688
Dazed & Confused
Our first van was a 2003 Lifestyle (Sundance) 590RL, I think there was a bank of fuses in the large cupboard/wardrobe near the RCD etc, but we never encountered the same symptom as you without the RCD switch having tripped (due to dodgy fridge in our case, needed a new circuit board). If you are on a site, have you tried alternative EHU point or cable as a test?
Feb 9, 2015
255
1,150
Warrington
IH Oregon R
Are you sure the Ehu has not tripped at source
