Suitable Fuse for a 1500 PSW Inverter (1 Viewer)
Jun 19, 2014
41
26
Cardiff
Low Profile
I'm a newbie
Hi I am looking to fuse on the DC side a 1500 PSW Inverter running small items ie tv,mobile phone charging, electric bike charging, laptop .Is there a formula for working out the size of fuse. All help appreciated. Robert.
scotjimland
2,231
9,713
A Woosh bang
Fuses are fitted to protect the cable from overload / overheating.. so the fuse size should be calculated to the max safe full load current of the cable..
A 1500 watt inverter on full load will draw: w/v = 1500/12 = 125A
do you know what size the cable is .. ?
are you using what has been supplied or fitting your own ?
and if so what is the length ?
For example.. if your cable run is 1 mt you will need 25mm cable (acceptable loss of 2%)
that should be protected by a 125A Fuse.
you can calculate cable sizes here http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
SAKURA
Jun 19, 2014
41
26
Cardiff
Low Profile
I'm a newbie
Thanks very useful info have bookmarked site. Robert
