cris5555
I need to replace my Suburban water heater in my Safari, does anyone know the best and cheapest firm to go to, any help appreciated.
Ah OK if its definatly leaking. I had one on my old Rockwood that used to leak from the presure releaf valve,when the boiler was first lit and the water was building up presure. I cured this by turning off the water pump and leaving the hot water tap open until water was hot, then turn tap off and switch pump back on.Hi, the bottom cowling on the front of the tank is rusted with a small hole, there is a leak from somewhere behind the cowling that has been leaking for sometime but has recently got worse and we noticed damp in the carpet, the heater is 14yrs old and we are fulltiming so we thought best to replace.
