Submersible Water Pumps (1 Viewer)
Jan 5, 2015
21
6
Les Cabannes / France
Chausson 640
newbie
12v 19l/m submersible water pump packed up after only 21 years use
anyone have any ideas on which to buy, which to avoid ?
There also seems to be a small coarse filter in line which broke during removal, do we think this is necessary ?
Tony
Feb 29, 2012
361
225
Reading & Surgeres France.
Hymer 584
Motor homing since 1998.
The Reich tandem works well in our Hymer. Did try to uprate to the 25lt one but it was far too noisy, took it out again, back to a tandem.
Barrie
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
Here you are - remember to specify the version with the non-return valve. Also, keep and take care of the clip-on grit filter off the bottom of the old pump and the screw-on pipe fittings that hold the pump to the tank top as these are hard to get.
Link Removed
Lenny HB
53,410
149,877
On the coast in West Sussex
Hymer B678 DL
Link Removed
Check the pump before ordering our pump does not have a non return valve, it is in the pipe outside the tank.
