Stuttering autosleeper (1 Viewer)
cobmonster
56
Wokingham, Berkshire
9 years
Hi can any body help with a solution to stop my 1996 Peugeot 2l petrol auto sleeper stuttering.
To explain when driving it is fine through all gears apart from fith when engaged moves along with a stutter as soon as any acceleration is applied, it does not matter what speed it is doing when it happens.
So far the plugs and leads have been replaced and the petrol filter.
Any help would be appreciated as spending on parts not required is a pain.
Thank you Tony
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Sounds like a weak mixture
I would be checking very very carefully all inlet joints and rubber pipework for splits, whilst engine is ticking over spray some carb cleaner around the manifold areas if speed picks up you have found your air leak
Dont cause a fire Keep away from heat source ie exhaust manifold
Geo
43,319
49,397
if it runs ok in the first 4 gears i cant see how fifth can affect the engine......
sounds like a gearbox fault to me.
the only other thing i can think is if selecting fifth is somehow interfering with the ignition wiring under the dash in some way...possible poorly routed wiring being disturbed by the gear lever mechanism etc.
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
...or it's there all the way through but most noticable in fifth?
Is it violent or gentle?
Fuel starvation possible, pump type issues, or air leaks around the inlet?
Fuel age, is the van used regularly, just a thought if it's been standing a while, or shorter trips, ie you haven't filled up for a good while, though we're talking months here unless you've picked up some iffy petrol?
cobmonster
cobmonster
56
9 years
The van is used daily and there is no hesitation through the gears and the engine is sweet as a nut and free reving which makes it seem so daft, I have had the mechanic drive the van also and it is for sure engine.
If it were air leaks would it be affected in the other gears ?
Tony
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Tony
Then, I can safely say ignor me:ROFLMAO:
Sounds a right odd ball?
normanandsue
1,871
21,571
Dunfermline - Scotland
van conversion
Thank you Tony
Tony this may/may not help. I have a Peugeot Autosleeper 2ltr petrol/ lpg and have expereinced the same thing, shuddering/misfiring in 5th gear and a alck of power on hills or inclines. As you have not mentioned lpg I am assuming you have not had a conversion which was the cause of my problem.
The garage were mystified until they tested the engine's compression and found the compression was low on no.1 cylinder; taking the head off revealed a burned out exhaust valve.
If all else fails it may be worth having the compression checked.
Hope this is not your problem as its mega bucks to fix
Good luck
Norman
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I'm going to stick my neck out and suggest that the spring in the fuel lift pump has rusted through. I had exactly the same fault on a 1983 fiat 131. By the time you get to 5th gear and try to accelerate the float chamber is severely depleted, try to accelerate in 5th and the reduced fuel pressure leaves you with fuel starvation and a spluttering engine.
D.
43,319
49,397
D.
couldnt say for sure as i dont know the engine but i would think at 1996 it would be fuel injection with an electric pump
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
D.
Come on Dave call yer sen a mechanic:Doh:
Which coil on the spring
top middle or bottom:Doh::ROFLMAO:
