Stupid question time
Discussion in 'American RV's' started by WinnietheBrave, Jun 29, 2010.
  1. WinnietheBrave
    WinnietheBrave Read Only Funster
    Jun 28, 2010
    187
    17
    S. Wales
    I have a 91/92 winniebago brave, I have most manuals for the appliances, but not one for it self, like what switches do what etc.
    I have three switches on the left side of the dash, top one is for the radio to switch over to aux battery from main.
    The second one says mom on one side and dual on the other, not sure what tis does?
    The third switches on/off the aux batteries.
    Can anyone explain exactly what they all do, or in what situation they need to be used?
    When hooking up to a site supply, I always seem to trip either their supply or mine, put it on a second time and it seems fine, what could be the cause of this?
    I have a load more questions to come but i'll start with these:RollEyes:
  2. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    Hi and welcome to fun
    cant answer your questions but certainly with the switches one, if you post a photo someone might recognise the set up and help you xxxx
    good luck
  3. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    Cheer's OCBT I will do that tomorrow, I keep her at work.
  4. motorvating
    motorvating Read Only Funster
    Feb 28, 2010
    121
    28
    Hinckley
    I would ask the question at a sister site of this for RV's.
    http://www.rvoc.co.uk/
    I can't tell you about the buttons but I can about the tripping. RV's are power hungary beasts and will often trip a site leccy because they are often supplying less amps then the RV wants. This is very common on the continent.
    I have learned through experience on poor leccy supplies to switch everything off before connecting the land line, and then gradually switch on what I need. During peak times of the day e.g. dinner you are more likely to trip the leccy because everybody is drawing on the mains of the site.
  5. PeteH
    PeteH Funster
    Nov 22, 2007
    2,308
    2,810
    East Yorkshire
    Not so stupid question?
    Don`t put yourself down we`ve ALL been there!!!!
    Switches:- Try this and search for your Model? ( http://www.winnebagoind.com/service/submenu/1997.htm )
    Tripping the site Supply:- More than likely you have a transformer to reduce the 240V to 110? if so, there is a known electrical effect which allows that most transformers will take a brief "surge" on first switch on enough to trip the supply, especially if there is a big load on as well. On some sites I have to switch everything off, then boot up the site supply, and then put everything back on, one item at the time.
    I also know from bitter experience that if you have even the SMALLEST earth leakage, some site trips will drop out and not reset (mine was on the geny; and the only way to "defeat" it was to fit a DUAL pole isolator to switch the genny out when on "shore supply")
    That is BOTH Live AND Neutral Phases.
    Best of Luck
    Pete
  6. eddievanbitz
    eddievanbitz Trader - Funster
    Oct 4, 2007
    3,990
    12,403
    Taunton Somerset
    Hi the mom and dual is for using all of the batteries to start in the case of low starter batteries from memory.
    The tripping is caused by the rated speed of the RCCD being faster than the transformer can cope with. We supply a wire in wire out solution to this problem which is in effect a soft start relay which eliminates this often annoying, always inconvenient problem.
    Hope this helps
    Eddie
  7. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    Thanks Pete, I will try switching everything off next time I'm out.
    I had a look at that site, very useful, sadly they don't do my model (WCF23RC) too old? to short? The van, not me....well maybe me!
  8. Moosehead
    Moosehead Read Only Funster
    Aug 13, 2009
    19
    Staffs
    Top switch allows radio to run off leisure batterys - and effectively mains when on hook up as the leisure batts are being charged. We have a cd unit with aux in plug which we use as surround sound for the tv as we have speakers in the dining/sofa area.
    The second switch allows you to connect the leisure batts to the engine batt momentarily - Only to be used for 'jump' starting if you have run the engine batt flat.
    Third switch turns off the leisure batts - for use when in storage to stop discharge over time. Note: If you ever find that you have no interior lamps, water pump etc, check this switch is in the on position before you start searching for blown fuses, dodgy wires like somebody did:Blush:
  9. WinnietheBrave
    Jun 28, 2010
    187
    17
    S. Wales
    Moosehead, the mom/dual switch, what's happening when in the dual position?
    Also do I have to have the Aux Batteries on when plugged into a hook up?
  10. Moosehead
    Aug 13, 2009
    19
    Staffs
    Err dunno. Mine is just marked 'MOM' and is a sprung switch that returns to the blank side. Does your switch have more than 2 positions then?
    I leave my Aux batteries switched on all the time. I'm guessing that turning them off when on hook up will mean they will not be getting charged.
    Be quick with any more questions:Wink: - I'm off to Cornwall in an hour or so, won't have pc with me. Back on Monday night
