Stuck again (1 Viewer)
Feb 22, 2014
2,107
10,269
Grantham
Rapido Le Randonneur
Since 2015
damn fan belt has broken now! Hopefully fixed tomorrow but getting a bit fed up of breakdowns now. Out of our 25 day holiday 7 days we've been laid up due to mechanical problems! Hells bells....is this punishment for voting leave? :rolleyes:
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Or maybe lack of regular maintenance , perhaps? or even poor maintenance.
Cheers, Dave(y)
Reactions: JJ
Feb 22, 2008
12,258
44,933
Norfolk
Nearly Tugging
Since 2004
Be worth checking if timing belt needs changing , that's a real good un :eek:
PP Bear
7,735
28,138
Kent, UK
Auto Trail Dakota SE
Defo worth checking....
big map
4,597
182,265
Poole
Since 2009
@Cat53 your trip sounds like one of our normal trips away. These things are just part of your journey. Relax, enjoy and continue. You are living the life (y)
DBK
17,969
47,804
Plympton, Devon
PVC, Murvi Morocco
Well it's had two services and its MOT. And we only got her in October.
The condition of drive belts should be checked during a service for cracking and fraying. However, they wouldn't be checked if you just had a quick oil and filter change and wouldn't be looked at for the MOT.
As mentioned if your engine has a timing belt check from any receipts you might have when it was last replaced because failure can mean a new engine. :)
Scattycat
920
1,262
Mayenne, France
Rapido
Since 2010
YES!!!!!!!
Apr 11, 2015
5,353
54,332
hull
Laika Ecovip 300
If timing belt has been done, check that they did new tensioners as well, my car didn't, belt was fine tensioners snapped, same result, engine rebuild required.
Cat53
Feb 22, 2014
2,107
10,269
Grantham
Since 2015
It's definitely the fan belt....have the bits to prove it. Plus if a new engine costs thousands we wouldn't bother cos Winnie only cost us £3500. And no, I haven't left a zero off!
Reactions: DBK
teensvan99
231
250
Margate
coachbuilt
With any van that has little or no service history change all belts. Should be done every 5 years or stated handbook mileage. Worst thing for any belt is being in one set position for months at a time.
Cat53
Feb 22, 2014
2,107
10,269
Grantham
Since 2015
Thanks all. Fan belt sorted. Winnie running better than ever now. No more problems and are now back home. In every other way she suits us fine, except that the lack of a vehicle for excursions meant we didn't see as much as we would have liked. Didn't help that our son pranged his car so was unable to give us the promised guided tours. Darn it. Sat Nav packed up too, but then I blame Steve for that one. He bought a cheap download. Very false economy as it turns out!
Vlad The Impaler
1,633
2,227
Rutland
Since 2012 but longer in my dreams
Yes,
My British van has been running like a dream since the good news.
Apparently a lot of European vans are trembling about the uncertainty causing multiple faults.
Vlad
