Stripped Screw
Discussion in 'Motorhome Chat' started by Timotei, Feb 8, 2016.
  1. Timotei
    Timotei Funster
    Jul 23, 2012
    51
    72
    Kingswinford
    Anyone got any ideas how to repair a stripped thread in chipboard?
    OH keeps putting tins, bottles, any other heavy stuff you can think of in the deep bottom drawer in the MH. I suspect the hinge dropped slightly, which meant the catch was only just making with the latch plate so when I went round a roundabout all that weight pulled the screw out of the drawer front. When I checked all the other screws found that most of them tightened slightly.
    Catch is on inside of drawer front so need to careful of screw length so it doesn't pierce drawer front.
    Thought about filling screw hole with glue, then refit screw when dry but think glue will crack, any other suggestions (useful) will be considered
    Tim
  2. Borderland
    Borderland Funster
    Nov 5, 2014
    450
    2,508
    Borders
    could you drill out screw hole and glue a bit of dowel in
    • Useful Useful x 3
    • Like it Like it x 1
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,906
    10,283
    a matchstick dipped in pva woodglue to fill the hole. then when dry carefully level surface with a sharp knife and reinstall screw
    • Like it Like it x 8
    • Useful Useful x 1
  4. John Laidler
    John Laidler Funster
    Jan 9, 2013
    9,046
    12,404
    Plympton, Devon
  5. Smith and Sharp
    Smith and Sharp Funster
    May 31, 2015
    1,709
    2,671
    Cornwall
    That's the one....(y)
    • Like it Like it x 2
  6. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,591
    2,784
    Surrey
    I am damned if I know what the name of these things are, but essentially, it is a large bore piece of metal that you screw into the chipboard. It contains a smaller screw hole in the centre. They are sold in most DIY stores to repair stripped chipboard threads!
    So all you do is drill out the hole, screw one of these in, and then screw new screws into the centre of the thingy, hope you understand my rambling! :D
    • Informative Informative x 1
  7. Timotei
    Timotei Funster
    Jul 23, 2012
    51
    72
    Kingswinford
    'Matchstick dipped in glue' sounds the way to go - simples really, wish I still had a brain
    Thanks a lot, will try this when I can
    Tim
    • Like it Like it x 3
  8. JFD
    JFD Funster
    Apr 9, 2015
    122
    71
    Surrey
    Fill the hole with glue, and fit the screw whilst glue still wet. That way you get max adhesion to both screw and rough chipboard hole?
  9. Yorick
    Yorick Funster
    Oct 1, 2013
    4,109
    6,031
    Lanzarote
    I've used matchsticks to fix rawl plugs for years ;)
  10. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,591
    2,784
    Surrey
  11. The Wino
    The Wino Funster
    Mar 23, 2012
    1,296
    2,388
    leicester
    Fill hole with araldite when set drill a pilot hole just smaller than screw then fit screw in
  12. Mr Ed
    Mr Ed Funster
    Dec 18, 2010
    583
    576
    Norfolk.
    Why not move catch and plate 1" left or right ?
  13. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    I've had success doing that with Cuprinol Wood Filler in the past.
  14. scotjimland
    Jul 25, 2007
    28,975
    25,674
    Chipboard in a Burstner.. :eek:
    :whistle:
  15. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    562
    826
    Nr Hastings, East Sussex
    Depends on the extent of the damage to the existing hole. The matchstick trick is great if there's not much damage and the hole is reasonably deep otherwise, like @GJH I'd go for the Cuprinol Wood Filler instead.
  16. funflair
    funflair Funster Life Member
    Dec 11, 2013
    5,604
    5,835
    Guisborough
    As TheBig1 and others say matchstick or I use a cocktail stick dipped into PVA wood glue, stick it in the hole snap off and then possibly other 1 or 2 and then screw the screw straight in and let it all set, anything else is just making an easy job difficult.
    Martin
  17. Tootles
    Tootles Funster
    Sep 14, 2013
    9,318
    33,512
    Lancaster
    Throw the damned thing away, get your hand in your pocket, and buy a decent Hymer........:);)
    • Funny Funny x 1
  18. GJH
    Aug 20, 2007
    27,349
    34,949
    I knew Guisborough was posh but didn't realise the residents were above using common old matchsticks :LOL::LOL:
    • Funny Funny x 1
  19. funflair
    Dec 11, 2013
    5,604
    5,835
    Guisborough
    I should have add but you never get stripped screws in Niesmann+Bischoff,
    But you do, especially if you are a rough a--e.
    PS no matches in our van, and the advantage is that the cocktail sticks are smaller so 3 of them keep the screw on the centre of the hole, or am I taking this too seriously.
    Martin
    • Funny Funny x 2
  20. Bill_OR
    Bill_OR Funster
    Dec 11, 2011
    562
    826
    This thread has just reminded me of one of the favourite sayings of my woodwork teacher, Dick Mabey at Sandown on the Isle of Wight, "In glue and dust we put our trust. If all else fails then putty must!"
    • Funny Funny x 1
Similar Threads
  1. emmitdb
    4
    404
