strange one ?
Discussion in 'Tech/Mech General' started by Figaro, Feb 2, 2016.
  1. Figaro
    Figaro Funster
    Feb 22, 2011
    1,055
    823
    Newcastle under Lyme Staffordshire
    Over the past 6-9 months, sometimes when I turn off the engine and remove the ignition key, the side lights will come on on their own. Light switch in off position and stalk untouched.
    This used to catch me out and I'd only notice when outside the vehicle but I always look now for the green indicator light on dash. Putting key back in ignition turns them off :confused:
    Not a big problem but just concerned it may be a sign of something failing.
    It's a 2003 Hymer on ducato 2.8 jtg and in all other respects runs fine.
  2. andy63
    andy63 Funster
    Jan 19, 2014
    2,228
    8,542
    south shields
    Hi. Have you left them on ,to see if they turn off after a certain time has lapsed,,say 5 or 10 min... It takes time for things to shut down on a modern vehicle.... and I'm not trying to imply what's happening is right but it may be a glitch say of activation of parking lights which is activating when it shouldn't. ..
    Such things usually mean a trip to the dealers or sometimes,, say after a battery disconnect they just go away...
    Ta andy.
  3. Figaro
    Figaro Funster
    Feb 22, 2011
    1,055
    823
    Hi Andy, no I've never left them on but I will next time it happens. I'd guess 15 minutes should be long enough for everything to shut down ?
    I wonder if it's worth disconnecting the battery for half an hour then reconnect.
    Like I said it's never been a big problem, just an annoying mystery.
    • Like it Like it x 1
  4. Tootles
    Tootles Funster
    Sep 14, 2013
    9,253
    33,164
    Lancaster
    My old Hymer has a separate button that brings on the sidelights when the ignition is off, should I so desire it...........Has yours?? Ignition off, green light comes on the dash. o_O
  5. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    Does yours have the little button(part of the ignition switch) which you can press as you turn the ignition off maybe?
    [​IMG]
    • Useful Useful x 1
  6. andy63
    andy63 Funster
    Jan 19, 2014
    2,228
    8,542
    south shields
    Well I know it takes my transit around 7 min. .. If I sit quietly I can hear the relay click..
    I can get away with disconnecting my batteries and everything fires up ok after a reconnection but it's not always the case ...but you have to find out sometime so I bit the bullet and got lucky lol.
    Maybe check with dealer to see if they think it would cause a problem..
    Good luck.
    Andy
  7. Figaro
    Figaro Funster
    Feb 22, 2011
    1,055
    823
    @Tootles & @dp Jay I've no idea but ill have a look later. Not aware of that button !
  8. Al-Di
    Al-Di Funster
    Mar 15, 2014
    1,016
    4,083
    prestwich
    the button is to release the key,
  9. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    10,463
    11,826
    E Yorks
    ... perhaps it's haunted .....
    [​IMG]
  10. Serendipitous
    Serendipitous Funster
    Aug 4, 2012
    347
    285
    Devizes
    Think the button allows the key to turn into the park position so that things like the parking lights work and maybe the radio, when the key is removed.
    This arrangement was on an old punto and occasionally caught us out ending up with a flat battery.
    Such an arrangement would tie up with the explanation as the key may not have always been put in the park position.
    Who knows!
  11. Badknee
    Badknee Funster
    Aug 25, 2014
    3,790
    16,816
    notloB
    Angela's Picasso takes ages to shut down, there's fans, whines and clicking going on for about five minutes. I thought the radiator cooling fans were running but it's not them, there's another somewhere. No lights though.
  12. DP_JAY
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    On some models pressing the button when removing the key was the only way to put the side/parking lights on without the ignition on.
    Used to catch MoT testers out when it was first introduced.
  13. DP_JAY
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    Have you resolved your problem?
  14. Figaro
    Figaro Funster
    Feb 22, 2011
    1,055
    823
    No I haven`t but I have a photo of the ignition. I don`t think there is a button to press
  15. Serendipitous
    Aug 4, 2012
    347
    285
    Devizes
    The button is the black bit and the switch clearly shows a park position which is only accessed by pressing the switch and turning the key an extra click.
    If fingers kept well away from the black bit you will find the key only turns to the stop position.
  16. movan
    movan Funster Life Member
    Dec 2, 2009
    13,966
    25,428
    Moving around
    Figaro, sorry if this sounds stupid but do you have a panel which shows whether the battery is using a small amount of power? If it is then I know the short period of time the side lights are on may not seem to be a problem but even when they go off, if there is a problem they could be using power.
    I had a small fault where something appeared to go off, not going into it now as there was a huge thread on it, and my battery was flat as a pancake when I went to collect it after a few weeks and I didn't know why as it was a good battery.
  17. mustaphapint
    mustaphapint Funster
    Oct 9, 2015
    566
    1,066
    Worcestershire and Brittany
    I couldn't work out how to put the parking lights on mine (Fiat 2.8) until I read this. The button shown above allows the key to turn one extra click anti-clockwise and puts the parking lights on.
  18. DP_JAY
    Mar 17, 2010
    1,806
    1,027
    Cark, Cumbria
    Yes you clearly have "the button"! Just a slightly different button.
    The darker coloured section @ the 5.30 position.
    [​IMG]
  19. Figaro
    Figaro Funster
    Feb 22, 2011
    1,055
    823
    Ok, so what does it do, could it cause the side lights to come on ?
    I can have a look in the manual tomorrow but maybe you know ?
    TIA
    Chris
