Storing up MH for a number of months
Discussion in 'Motorhome Chat' started by errpaul, Nov 8, 2010.
  1. errpaul
    errpaul Funster
    Feb 27, 2009
    501
    58
    Wiltshire
    We're going to be storing our MH up now as pregnant Mrs L is not able to get comfy, and our house needs to be sorted for the impending addition!:Wink:
    This means no more trips in the van for quite a few months. Also as we can no longer fit the van on the drive we are storing at a storage site away from home.
    Now last year we had no issues as kept our old van on the drive with heater and dehumidifier on in between trips, and used it throughout winter.
    So the question is on the best prep to store it up. From what I can find out this is what I need to do:
    Water systems drained.
    Taps closed.
    Plugs in.
    Leave storage lockers open.
    Dehumidifier crystals or salt in pots.
    Leisure battery isolation off.
    The site where it is being stored is not hard-standing.....is it worth taking patio slabs and placing these so the tyres are on these rather than grass?
    Do I need to cover the tyres?
    Is it a good idea to put the external screens on?
    Window blinds up or down?
    :Blush:
    Also how often would you say to start up (max).
    Are those solar trickle chargers any good too keep engine battery topped up?
    Its an 03 ducato base and so need to keep engine battery connected for van security for insurance purposes.
    :Blush:
    Thank you:BigGrin:
  2. cyclingdoglucy
    cyclingdoglucy Read Only Funster
    Apr 27, 2009
    100
    lancashire
    taps
    hi .
    i would leave the taps open & in the centre position.:thumb:
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,418
    5,442
    East Sussex 01-580-881288
    You should if possible give the van a short drive once a month to clean the brake discs and to get everything moving.
    Dash board solar charger is a good idea, not expensive and save a lot of agro if the battery goes flat. Caravan Motorhome Solar Panel Battery Charger 12v
    Just make sure it is connected to the battery, some cigar lighter sockets need the ignition on first, if so use the croc clips direct
    Peter
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    Yes...and dont forget the toilet flush tank, water heater and water filter if you have one. also remove the shower hose after blowing down it with the taps open to expel any water.
    Taps closed.
    No....leave open and in center position
    Plugs in.
    Yes
    all doors open including wardrobe
    Yes but they wont last long before needing replacing
    Yes...unless you have a proper solar panel
    pieces of ply/short planks will do the job
    No need in winter...its the sun that does the damage
    Not worth it...no heat to retain.
    Up...the return springs will suffer if pulled down for extended time
    as the alarm is powered from the engine battery it wont last more than 3 or 4 weeks and still be able to start the engine.
    half an hour every 2 to 3 weeks will put enough back in.
    dash board solar panels are useless in winter...they'll produce milliamps at best.
    put a little olive oil on the toilet blade....stops the seal drying out and sticking.
    remove all packet foods...pasta etc and as daft as it sounds....put some broken digestive biscuit on a saucer on the floor.
    if you get rodents coming in they'll eat the biccies and you'll know they are there and can take action but wont have an endless supply of food.
  5. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    a little off topic but congratulations to Mrs L on the pending delivery xxxxxx
    Hope the little one brings great joy xxxx
  6. dylan
    dylan Read Only Funster
    Aug 31, 2007
    4,162
    569
    sw wales
    and from me too :thumb:
  7. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,604
    Ilfracombe, Devon
    don't forget to leave handbrake of, and operate clutch frequently, drive at least once a month to recharge batteries and clear brakes from sticking.
    Parked on grass is just asking for a rodent infestation, they love to chew electric cables. park elswhere if at all possible.
  8. errpaul
    errpaul Funster
    Feb 27, 2009
    501
    58
    Wiltshire
    Thank you both....can't wait until he/she arrives. We chose not to find out the sex so it'll be a surprise.....still a few months left until due though!
  9. errpaul
    errpaul Funster
    Feb 27, 2009
    501
    58
    Wiltshire
    Thanks all for the advice.
    Unfortunately there isn't anywhere else to store it....very short on sites here unless you wanna pay £500 a year.....:Eeek: don't need too many guesses to see why they've still got space!
    Is there anything that can be donbe to help prevent rodents? Obviously remove all food, as papa john's advice, but are there things that can be sealed up?
    The previous owner obviously had a rodent infestation at some point....took half the thing apart cleaning up their droppings once we got it....don't want to have to do that again!
    Would the biscuit thing not attract rodent and insects etc?
