Storage . What needs doing ?
Discussion in 'Motorhome Chat' started by Charlie, Sep 18, 2015.
  1. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Our van won't get used now until after Christmas when we head to Spain..
    Today I drained the water tank and opened the valve to drop the water out of the heater. Opened all the taps in the sinks and shower and set them in halfway position between hot and cold. Emptied the loo both the cassette and the flush water tank.
    What else should I do !
    Do I leave The window blinds open or closed
    Is it worth putting a couple of thos dehumidifier things in the van ?
    Any advice welcomed.
    Thanks !!!
  2. Clickem
    Clickem Funster
    May 20, 2014
    315
    173
    Northumberland
    Definitely recommend dehumidifies, we use Poundland.
    Make sure that you remove any food and set a couple of mouse traps, just in case
    • Like it Like it x 1
  3. scotjimland
    Jul 25, 2007
    29,041
    25,732
    Suffolk
  4. scotjimland
    Jul 25, 2007
    29,041
    25,732
    Suffolk
  5. dave met
    dave met Funster Life Member
    Jan 7, 2014
    101
    61
    cheltenham
    I take mine for a spin every 4-6 weeks for about 20 mins,and I mark the bottom of the tyres before I set off and make sure the area marked is in a different position when I return. And a good idea to remove food,but I don't set mouse traps as you are just leaving food on them to invite them in
  6. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Thanks Jim.. The section that covers inline water filters is one area I would have missed ! I will attend to that !
    The biscuit test is also good but I will be putting a couple of traps in the van and putting them on a piece of card as traps can spread mouse blood a good distance !
    Thanks again !
  7. Ja63
    Ja63
    Jun 28, 2015
    85
    192
    Cannock
    We used to have a static caravan and it was closed November to March each year. We (and everyone else on the site) used to put about 4 big dishes of salt around the vans to absorb any damp. We owned the van for about 6 years and never had any damp or mildew when we went back to open up.....and the salt was rock hard so it must've absorbed moisture!
    We also used to stand all the cushions up on end, away from the walls.
    Also, in the motorhome, I'd leave the toilet cassette out with the lid off to let it dry out..... Not sure what would grow in there if left in situ? And, leave the fridge and freezer doors wedged open to avoid them getting mildewy and smelly.
  8. DanielFord
    DanielFord Funster
    Jun 1, 2013
    2,629
    2,813
    Surrey
    Depends on the type of blind, if they are sprung loaded, no. If not, then entirely up to you.
    If you have a separate toilet flush tank, you'll need to empty that, but I would guess you don't have one. Final small but important point. Don't leave the handbrake on, if it seizes up in the on position, that is a big job. Easy to repair if the handbrake is not applied.
    • Like it Like it x 2
  9. bubble63
    bubble63 Funster
    Aug 10, 2012
    606
    557
    cambridge
    MOUSE TRAPS...............STICKY ONES IF YOU MUST BUT........... MOUSE TRAPS
    Am I shouting ...........YES
    Had loads of damage last winter, they ate all the waste pipes then made a nest in the void under the shower
  10. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Toilet does have a separate flush tank and that has been emptied including the siphon/filling spout at the top.
    Believe it or not I never leave the handbrake on . I always park it in reverse gear with a chunk of railway sleeper chocking the rear wheels..
  11. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Good idea on leaving the toilet cassette out.. I've cleaned it really well inside and out but if it's not in the van it can't smell... I will put it in the back workshop out of the way...
    Have the fridge/freezer door open and one of those fridge fresheners inside..
  12. Ja63
    Ja63
    Jun 28, 2015
    85
    192
    Cannock
    Just thinking what your first thread about Spain might be.......'Guess who forgot to put the cassette back in?'
    I'd stick a post-it note on the loo lid if I were you......
    • Like it Like it x 5
  13. berni109
    berni109 Funster
    Sep 10, 2012
    383
    305
    worcester
    I use a compressed air line to blow out any water still in tap fittings after having ice force a tap apart.
    I Do this by taking the shower head off but make sure the taps are open or u may cause the non return valve to jam. No need to ask how I know this.
  14. markh
    markh Read Only Funster
    Jun 4, 2014
    247
    243
    Nothing needs doing if you keep indoors in a heated, solar powered garage, then it's always ready to go, just supply an alternative food source for mice and they won't come near it, I use 2000 tonnes of wheat
    • Like it Like it x 3
  15. bubble63
    bubble63 Funster
    Aug 10, 2012
    606
    557
    cambridge
    bit over the top with the wheat mate, but still if it works for you
  16. Hobbytwo
    Hobbytwo Read Only Funster
    Feb 18, 2014
    38
    32
    Hertfordshire
    Even having drained the system down, a pool of water will probably remain in the basin or shower U bends/traps which can freeze and then crack the plastic. I pour a bit of antifreeze in after draining down.
  17. Bacchus
    Bacchus Funster
    Jul 27, 2015
    423
    4,292
    Staines
    I make sure the engine is off and close the door...
    Having had an attack of diesel bug on the boat I would make sure the fuel tank is full nowadays, but I think the best advice as @dave met says is to try and use it!
    Oh, also to leave the handbrake off, and the guy who fitted my clutch told me to try and wedge the clutch down with a stick.
  18. Hogan7777
    Hogan7777 Read Only Funster
    Sep 28, 2014
    76
    137
    Valencia, Spain
    Leave hand brake off. Do not leave in gear if you have a DM Flywheel.
  19. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Assuming the advice on the clutch was to prevent the plate sticking to the flywheel raises the question of continuous loading of the clutch springs ?
    Its not hard to get a plate unstuck IF it sticks. Use will then clean it up. Bugger the springs and its gearbox out time..
    Least that's the way I see it .
  20. Charlie
    Charlie Funster
    May 16, 2015
    2,666
    3,143
    Please explain why ?
    Thanks.
