Stiff Garage Door (2 Viewers)
Debs
6,302
181,589
West Notts
A class Adria Vision
Can anyone advise please?
The garage door has gradually become stiffer and we wonder how the hinges are supposed to be greased as there's nothing obvious (Les believes that wd40 shouldn't be used).
Photos att'd - please ignore the grime, been tied up hospital visiting.
Deb
Jan 8, 2013
8,490
11,527
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Its because its aluminium on aluminium I guess, both have furred up.
If would be good to remove the plastic covers and try and get some thicker oil down the length of the hinge.
If you could lift the door of and grease the pivots - even better.
Debs
Debs
6,302
181,589
West Notts
Thanks for this.....Les will have a go shortly
Gandhi
170
303
Near Glossop
bessacar E496
5 years
Grease would be better than oil. If that top cap is plastic and can be popped off I'd get some good old gundgy greasy down there with a grease gun.
1,187
18,697
Chelmsford Essex
Getting better
I had the same problem on locker doors, new hinges were available at £40 a pair ( not even gold plated nor fitting included) so plan B remove doors from van,remove hinges from doors and using copious squirts of penetrating oil, some muscle and a vice managed to free up the hinge movement take apart, clean up oil and replace. Now all sorted. The problem is caused by the reaction between the aluminium hinge body and the brass hinge pin,allied to time grime and no maintenance by the previous owner.
You need to fix them now because stage two of the problem is for the aluminium hinge to fatigue, crack and fracture!!
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I have had a similar problem on mine. The Hymer handbook says use non-acid grease. I used silicone grease but in order to apply it properly, the door(s) need to be unhinged and the hinge-pins exposed so that they can be cleaned and re-greased. It was a bit fiddly getting the habitation and garage doors off, but worth while. (In fact, I combined it with removing the fly screen door so that I could fit new mesh.)
I found that trying to force lubricant down the hinges from the top plugs did not work. Also, don't use WD40 or similar as it just makes the problem worse over time.
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
WD40 is often suggested for such things then other people come along and say in the long run it attracts water (Never found that myself but will rely on the word of others). I would suggest building a dam out of putty or plasticine around the top of the hinge then filling with 3 in one oil and allow it to gradually work its way through the hinge pin.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Remove the hinges and separate the parts of each. Clean the pins with emery tape and drill out the plastic lined bodies (5mm from memory but best to check diameter of the pins). Re-assemble with a suitable lubricant.
D.
3,341
5,358
Pakefield, Lowestoft, Suffolk, UK
Looking
I didn't know you could get replacement fly screen mesh, could you say where from please.
Debs
Debs
6,302
181,589
West Notts
D.
Thanks all for the replies
Dave could I ask please - specifically how do the pins come out? Do you hammer from the top or bottom please?
Thanks.
JeanLuc
3,304
2,199
Warwickshire
D.
Pretty much what I did with mine Dave, except I didn't have to drill out the plastic linings.
1,372
4,148
Cheshire
Van Conversion
Been around the block a few times😉
Think they lift up so from the bottom or at least that's how our caravan works.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Thanks.
Depending on how badly they are seized they may just lift off or may need tapping apart with a hammer, in extreme cases they will be seized solid and replacement is the only realistic option.
D.
Debs
Debs
6,302
181,589
West Notts
D.
Sorry to be dim :blusher: but the hinge is about 7 inches long with the pin running the full length of the hinge - this means the door can't lift off, any ideas exactly how you get the pin out please?
JeanLuc
3,304
2,199
Warwickshire
Swing the door open then it should lift off. In my case, each hinge was a three-part unit (one base plate hinge attached to the frame, the centre one for the Remis fly-screen door and the other attached to the hab door hinge). The bottom one was fitted upside down so had to be removed before the door could be lifted off the top two hinges. In other words, the top leaf of the top two hinges was attached to the door and the bottom leaf of the bottom hinge also - thereby preventing the door from lifting up in normal use.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Debs I don't mean to be rude but if you can't see how to remove the door perhaps you should take it to a workshop for repair.
D.
Debs
Debs
6,302
181,589
West Notts
D.
Thanks everyone, Les oiled the hinge yesterday so is hoping that helps, not sure if the hinge is different to what most others are (it's on an Adria A class)....but worst case scenario we will get it in somewhere Dave.
Deb
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Deb
Had this problem on three tug hinges on a German built Fendt. I drilled and tapped then fitted grease nipples, pumped the centre (moving) section full of grease, until it started to show at the top and bottom, removed the grease nipples, and fitted push in plastic caps, then wiped off the surplus grease. (y)
11,862
43,010
Planet Earth
A van
Over 25 year's
ar
Deb[/Q
fix it meet next week debs I will fix it for you give it a spray with WD40 or duck oil to get you by till next week it will be first job on my the list
bill
