Sticky Electric step where to lubricate
Discussion in 'Motorhome Chat' started by SoapyTutti, Jul 3, 2013.
  1. SoapyTutti
    SoapyTutti Read Only Funster
    Jan 21, 2013
    71
    47
    East Yorkshire
    Hi Funsters,
    We are currently on tour in France in our Autotrail FB Tracker and really enjoying ourselves for the first time in a motorhome however like everywhere else in the world we have had a lot of heavy rain which I think every so often is affecting the electric step on the motorhome due to its location and all the spray battering it receives.
    I have used WD40 light engine oil and now a silicon lubricant in all the places visible and it seems to do the trick for a short time until as usual I go to start the engine and the step either sticks in the open position and will not retract.
    Do any of you very experienced funsters have any advice for me to cure this once and for all.
    Kind Regards
    Dave:Smile:
  2. John England
    John England Read Only Funster
    Feb 5, 2013
    Deal
    How old is your motorhome and does it have a Sargent control panel? If around 2010, there was a technical problem with a poly fuse on the printed circuit board, which produces the symptoms you are experiencing. It is necessary to replace the fuse (a soldering job). Sargent will tell you more.
  3. icantremember
    icantremember Funster
    Sep 2, 2010
    5,528
    7,656
    Nr Watton in Norfolk
    We had a similar problem with our step ... traced it back to the Sargent unit and after a call to their customer service team they sent me a complete replacement unit which I was able to fit quite easily.
  4. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,906
    9,435
    Tropical Bar,Benidorm.
    Hi Dave, have you cleaned and lubricated the micro switch on the step mechanism. Quite often they get clogged up with grit, a spray with WD-40 may cure the fault.
    Brisey.
  5. HymerB544
    HymerB544 Funster
    Apr 25, 2012
    730
    737
    Near Truro, Cornwall
    Sticking step
    Hi Dave
    When you've done all the above, I came across a tip related to this problem a few years back in one of the MH mags. Basically it involved fixing a plastic cover over the micro switch to protect it from spray, grit etc. the tipster used a hard, clear plastic lid from a small plastic box, similar to the ones you get bulb sets in. Not needed it on ours so I can't comment other than this, but the procedure seemed easy enough and the claimed result worked well. Not sure which mag but most likely to have been either MMM or Pactical Motorhome.
    Cheers and remember, every journey starts with a step :Rofl1:
  6. jenny and mitch
    jenny and mitch Funster
    Sep 16, 2010
    2,017
    1,752
    Bungay Suffolk
    Our Autotrail Tracker EKS had the same fault in Spain halfway down La Manga.. We had been driving through a lot of puddles, so I had a quick look under the step at the microswitch which is inside a plastic cover. I gave it a technically based thump and it worked faultlessly from then on.. So basically, the microswitch was stuck.. Hope this helps. PS. I do'n't mean that what the others have said is not correct, but this was my fault, and remedy.. Good luck..
    .Mitch. :thumb:
