Sticky discs (1 Viewer)
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
Anybody got a method of removing sticky discs, used to mount sat nav/dash cams etc., from the dash without, preferably, the use of industrial cutters. ( tis a Fiat Ducato.)
Geoff
eddie
8,156
41,254
Taunton Somerset
RV
since 1989
Twist it off or use a cheese wire underneath it (carefully obviously)
Then rub the remaining sticky pad off with your thumb, after gently heating it with a hair dryer, again carefully
Simples!
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Don't know if the sticky stuff is the same as labels, etc but if it is then use Goo Gone. Brilliant stuff - takes sticky residue off with a quick wipe.
Southdowners
3,358
25,320
West Sussex
Concorde Charisma
Since May 2015
Personally I would not use any kind of glue remover on a dash panel or top . As Eddie says Gentle heat and the stuff will roll off under a fingertip .
I've used it on all sorts of surfaces, matt and shiny, and never had a problem. It doesn't scour the surface at all and isn't harsh like an acetone based cleaner.
The Dotties
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
Thank you all for quick replies, shall give it a go.
Geoff
Wombles
10,808
11,132
SW England
Van Conversion
A few years now
Piece of string - nylon is best as stronger but cotton should do the Stick Stuff Remover (y)
Badknee
7,407
412,582
notloB
Vantage Neo
Living the dream.
Angle grinder works for me:cool: carefully though obviously and wipe the rest of the van off the disk with petrol and you can use it again(y)
That's a stupid answer! You've obviously not thought this threw have you. What happens if the OP hasn't got 230v of doesn't own a battery powered grinder? Tcsh, no the best way is a very sharp wood chisel and a big hammer, works every time. (y):LOL:
Apr 18, 2009
3,569
3,367
Englishman in Mid Wales
Hymer B584, A Class
Not long enough!
A neighbour suggested a oxy-acetylene cutter. I've now got grease on the drivers seat from the pipes!!. Any suggestions on grease remover?
And before this gets really silly, disc has disappeared so thanks to the sensible ones among us.
images
That'll be mine then yes(y)
Badknee
7,407
412,582
notloB
Vantage Neo
Living the dream.
Jizer, works a treat on engines covered in oil, rub it well in with a cut down paintbrush then power wash off, itleberieyt. (y)
Reactions: GJH
TheBig1
17,630
43,262
serious note....use a length of dental floss to cut through the pad and just leave the sticky base. then warm the glue with a hair drier and pick/rub off as much as possible. any remaining residue should break down with isopropyl alcohol or surgical spirit
ojibway
531
305
Eastbourne
Van Conversion
since 2005
All your names have been noted and you will shortly be visited by a men'al helf assesore or by the elf 'n safety officer or by the league of misleading information detection team.
All except the sensible ones;)
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
Nail polish remover?
Please dont use that stuff ! It has the capability to strip the surface off the dash in half a second.
I would not use any chemical or solvent. IPA included. All it needs is gentle and I do mean gentle heat and roll the glue of with yer finger. Wrong chemicals or brutality will leave a mark that for me would annoy the hell out of me for the duration I own a vehicle.
Tincataylor
639
1,360
Devon
Never leave a campsite with your clothes line tied to a lamp post.
Most sticky residues from labels and the like can be removed safely by rubbing with good old WD40
parknride
1,400
4,749
cumbria
c class
since 1988
be very careful, nailpolish remover will melt the surface of some plastics leaving a mark
Ooops sorry!
parknride
1,400
4,749
cumbria
c class
since 1988
It's no good at getting this sparkly nail polish off though:blusher: can't shift the stuff!
Badknee
7,407
412,582
notloB
Vantage Neo
Living the dream.
Errrrrrrrrrrrrwotareyoutryintersayeh?
Aug 19, 2015
639
11,767
West Sussex
Since 2015
Sticky residue from sellotape and pva glue comes off with gentle rubbing with little bit of windolene (pink stuff) on a cloth. Works really well, I never buy Goo Gone. Not sure of reaction on a dashboard though.
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
I had a really MINTY driver on the fleet and we had his tractor to clean out after he left, and I found he has a black vinyl seat in the cab??? the other one was light brown fabric. Then I cottoned on it was grease soaked and polished. I took it out and soaked it in degreaser then steam cleaned it thoroughly then let it dry. It was like new under that load of grease.
