Stick-On Wood Covering
Discussion in 'Motorhome Chat' started by Yorick, Sep 16, 2015.
  1. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
    Due to a cock up on holiday, I had to rip off the covering behind the sink/cooker.
    It's a very hard plastic sheet. Haven't a clue where to start looking :(
    Any idea where I can get some more ?
  2. GAVLAD
    GAVLAD Funster
    Jul 31, 2014
    638
    621
    West Yorkshire
    Try O'Leary motorhomes - they sell things like this for self builds
    • Like Like x 1
  3. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,510
    9,938
    that my friend is what used to be referred to as formica. it can be purchased all sorts of places but an exact match is unlikely
    try a smaller converter like rainbow conversions for an offcut or maybe O'learys
    • Like Like x 1
  4. jollyrodger
    jollyrodger Funster Life Member
    Oct 1, 2012
    3,575
    7,152
    Plymouth
    Formica ?
    B&QQ
    Easy enough to cut to size with a Stanley knife then trim edges with glass paper
    • Like Like x 1
  5. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
  6. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
    Formica. Was too obvious :whistle2:
    I thought the builders had stuck some coating onto a wood panel :clap2:
    Stupid boy ;)
    • Like Like x 1
  7. bartiny
    bartiny
    May 23, 2010
    284
    419
    Accrington, Lancashire
    • Like Like x 3
  8. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
  9. TheBig1
    Nov 27, 2011
    7,510
    9,938
  10. Speve
    Speve Funster
    Jul 29, 2013
    2,090
    1,827
    Salisbury
    There's also one called Planica same sort of thing only thinner.
    • Like Like x 1
  11. Daifuse
    Daifuse
    Feb 20, 2013
    184
    310
    Milford Haven
    A bit inferior but you could try FABLON.
    • Like Like x 1
  12. Doctor Dave
    Doctor Dave Funster
    May 18, 2015
    257
    538
    Wiltshire
    Or STICKY BACK PLASTIC as the used to say on Blue Peter (they may still do).
    Dave
  13. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
    Thanks, but it needs to be tough and hard wearing.
  14. Feltwell
    Feltwell Funster
    Aug 27, 2014
    397
    380
    Shropshire
    I used to sell the stuff. Formica is a brand name for High Pressure Laminate, which is what that is - same stuff as used on kitchen worktops. The good news is, go to a proper laminate wholesaler and they should be able to match that no problem, it looks fairly generic to me. Bad news is you may well have to buy a 8' x 4' sheet.
    Whereabouts are you? If you're heading South Coast way to go across the channel, then Stockmart Plastics in Portsmouth tend to keep offcuts. You might get lucky.
    Laminate is not easy stuff to cut, if you're not a confident DIY'r then I'd get a fabricator to do it for you.
    • Like Like x 1
  15. Yorick
    Yorick Funster
    Oct 1, 2013
    4,021
    5,948
    Lanzarote
    In Thame near Oxford.
  16. Feltwell
    Feltwell Funster
    Aug 27, 2014
    397
    380
    Shropshire
    OK. IDS in Swindon are a wholesaler and will be able to get you a sheet to DIY. If nothing else they'll have a huge selection of swatches for you to find a matching laminate to then give the code to a fabricator:-
    http://www.idsurfaces.co.uk/
    If you want to DIY then get all the old sheet off, and bond the new one in with contact adhesive. Be warned, laminate is brittle stuff, easy to break a sheet, and once stuck it won't come off without breaking it.
    My knowledge of fabricators in that area is rather out of date. Oxford Laminates may be worth a call, they are primarily involved in worktops but may fabricate a panel for you, I'm pretty sure they do fabrication work.
    http://www.oxfordlaminates.com/
    A bit of a way out but I'm positive that Lamform would be able to make a panel for you. They do all kinds of small fabrication jobs. And the owners are lovely!
    http://www.lamform.co.uk/
    And finally, as mentioned above, Stockmart in Portsmouth. A funny little place but don't let appearances deceive, they know their stuff. They will cut laminate to size and even advertise that they recover caravan tables. Probably your best bet I'd say. They *may* have something in stock, they keep all kinds of offcuts, but the match may not be exact (if that matters).
    http://www.stockmartplastics.co.uk/
    If you go to IDS then I'm 100% certain you'd find a very close match to that panel, but they won't cut or fix it for you and you'd need to buy a large sheet. Alternatively, take the code into Stockmart and they'll order a sheet from IDS and cut and fix it for you, for a price of course. Woodgrains are the hard ones to match, a metallic finish will be easier. Take in a bit of your broken panel.
    • Like Like x 1
